Would appreciate some tuning advice for new 2056, Having trouble dialing in the AFR |
rbzymek |
Oct 6 2019, 09:02 AM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
So I replaced the 1.8L with a SCAT 2056 long block with a Web 73 cam and 42x38 valves. They provided 4 bolt (intake) heads so I could use the 1.8 tin and carry over L-Jet system. The CR is 8.5 and I have an adjustable FPR. The injectors are stock 1.8L L-Ject. I can dial in the idle AFR easily but I get rich 9.0 AFR on very light tip in. I also go lean at higher speeds (>4000). I suspect the static is set too high on the AFM. Any suggestions?
Superhawk996 |
Oct 6 2019, 09:14 AM
914 Guru Group: Members Posts: 5,777 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
check out this link you may find it helpful.
http://www.914world.com/bbs2/index.php?sho...40434&st=20 |
914forme |
Oct 6 2019, 09:20 AM
Switch to Megasquirt, HalTec, AEM, SDS........... (IMG:style_emoticons/default/confused24.gif) you're expecting a lot from a system designed when it was. Can it be cleaned up, sure, is it worth spending huge amounts of time, nope.
Issue is your testing ancient technology with Modren tools and expecting Modren near perfect out comes. To get that you need a processor and data maps beyond what transistors and diodes with resistor can provide. (IMG:style_emoticons/default/dead horse.gif) |
rbzymek |
Oct 6 2019, 11:32 AM
Switch to Megasquirt, HalTec, AEM, SDS........... (IMG:style_emoticons/default/confused24.gif) you're expecting a lot from a system designed when it was. Can it be cleaned up, sure, is it worth spending huge amounts of time, nope. Issue is your testing ancient technology with Modren tools and expecting Modren near perfect out comes. To get that you need a processor and data maps beyond what transistors and diodes with resistor can provide. (IMG:style_emoticons/default/dead horse.gif) Stephen, I think with the L-Jet knobs at hand (fuel pressure, AFM static, AFM dynamic and CHT resistor adder if needed) I should be able to arrive at a safe calibration. Like 12.5-13.2 moderate load, maybe 12.0-12.5 WOT and 13.2-13.5 at idle. I think I will start with WOT calibration since that will determine my fuel pressure needed with the 1.8L injectors. Then I can adjust for moderate load and idle. |
914forme |
Oct 6 2019, 07:01 PM
Best of luck and let us know where you land.
ClayPerrine |
Oct 6 2019, 08:04 PM
Life's been good to me so far..... Group: Admin Posts: 15,435 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Go find 4 injectors for a Datsun/Nissan 208ZX, vintage 1980 or so. They are the same as the bosch injectors for a 912E, and work great with the L-Jet system. They are a complete bolt on, no mods needed. Make sure the intake has no vacuum leaks and verify the fuel pressure (28psi at idle with the vacuum hose hooked up) with a gauge. You just need it set to the stock pressure with the bigger injectors.
The 2056 won't kill the AFM from airflow, so you don't need to readjust the flap. Just use it as is. The cam will probably make it idle really poorly when cold, but once it is warmed up, it will run really well. Let me know if I can be of any additional help. Clay |
rbzymek |
Oct 6 2019, 08:35 PM
Go find 4 injectors for a Datsun/Nissan 208ZX, vintage 1980 or so. They are the same as the bosch injectors for a 912E, and work great with the L-Jet system. They are a complete bolt on, no mods needed. Make sure the intake has no vacuum leaks and verify the fuel pressure (28psi at idle with the vacuum hose hooked up) with a gauge. You just need it set to the stock pressure with the bigger injectors. The 2056 won't kill the AFM from airflow, so you don't need to readjust the flap. Just use it as is. The cam will probably make it idle really poorly when cold, but once it is warmed up, it will run really well. Let me know if I can be of any additional help. Clay Thanks for the advice. This will take some time with the other things going on. Regards Ray |
rbzymek |
Oct 7 2019, 06:27 AM
Go find 4 injectors for a Datsun/Nissan 208ZX, vintage 1980 or so. They are the same as the bosch injectors for a 912E, and work great with the L-Jet system. They are a complete bolt on, no mods needed. Make sure the intake has no vacuum leaks and verify the fuel pressure (28psi at idle with the vacuum hose hooked up) with a gauge. You just need it set to the stock pressure with the bigger injectors. The 2056 won't kill the AFM from airflow, so you don't need to readjust the flap. Just use it as is. The cam will probably make it idle really poorly when cold, but once it is warmed up, it will run really well. Let me know if I can be of any additional help. Clay Thanks for the advice. This will take some time with the other things going on. Regards Ray Clay, Wouldn't it make sense to also use a 912E (2.0L) L-Jet ECU on a 2056. It may have a better fuel map than the 1.8L ECU Have you heard if anyone has tried that or is it not required? Ray |
ClayPerrine |
Oct 7 2019, 06:54 AM
Go find 4 injectors for a Datsun/Nissan 208ZX, vintage 1980 or so. They are the same as the bosch injectors for a 912E, and work great with the L-Jet system. They are a complete bolt on, no mods needed. Make sure the intake has no vacuum leaks and verify the fuel pressure (28psi at idle with the vacuum hose hooked up) with a gauge. You just need it set to the stock pressure with the bigger injectors. The 2056 won't kill the AFM from airflow, so you don't need to readjust the flap. Just use it as is. The cam will probably make it idle really poorly when cold, but once it is warmed up, it will run really well. Let me know if I can be of any additional help. Clay Thanks for the advice. This will take some time with the other things going on. Regards Ray Clay, Wouldn't it make sense to also use a 912E (2.0L) L-Jet ECU on a 2056. It may have a better fuel map than the 1.8L ECU Have you heard if anyone has tried that or is it not required? Ray I have never tried it. It may be better, but the 912E ECU is hard to find. |
djway |
Oct 7 2019, 09:34 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
When trying to get the old tired 1.8 to run I just jumped on the freeway while watching the gauge under load then at cruise.
I would get off the freeway and adjust the spring pressure then hop back on the freeway. I kept doing it until the numbers looked acceptable. In my case it was dumping too much fuel so I tightened the spring. |
rbzymek |
Oct 8 2019, 05:17 AM
When trying to get the old tired 1.8 to run I just jumped on the freeway while watching the gauge under load then at cruise. I would get off the freeway and adjust the spring pressure then hop back on the freeway. I kept doing it until the numbers looked acceptable. In my case it was dumping too much fuel so I tightened the spring. Good plan. I have some FJ707 injectors on order which are replacements for 2.0 912 with L-Jet. I also have a fuel pressure regulator coming which is supposed to be for a 1.8 914 which should be 35 psi. All of the other FPR's I purchased are 40-42 psi. I will install the correct parts and give it a try. |
rbzymek |
Oct 10 2019, 02:15 PM
When trying to get the old tired 1.8 to run I just jumped on the freeway while watching the gauge under load then at cruise. I would get off the freeway and adjust the spring pressure then hop back on the freeway. I kept doing it until the numbers looked acceptable. In my case it was dumping too much fuel so I tightened the spring. Good plan. I have some FJ707 injectors on order which are replacements for 2.0 912 with L-Jet. I also have a fuel pressure regulator coming which is supposed to be for a 1.8 914 which should be 35 psi. All of the other FPR's I purchased are 40-42 psi. I will install the correct parts and give it a try. Clay, I installed the FJ707 General injectors and the Beck Arnley 158-0073 FPR both of which reference a 2.0L 912 engine. Engine off pushing the fuel flap I get 41 psi on the gauge. It shows about 34 psi gauge at idle with the vacuum compensation. After a good warm up run I adjusted the AFM to get 13.5 at idle and about 12- 12.5 at WOT. My RPM limit is 4000 RPM unlit after break in. The throttle body is a 45mm bus unit. The bad news is that I get 8.5 to 10.5 AFR at part throttle tip in with some rich misfire. Heavy crowd is 13-13.5. If I tighten the AFM then I get 15-18 AFR at idle---no good. I think the fuel pressure is too high but this is about the third FPR that I have tried. Another issue is that I cannot get the idle below 1200 even with the TB screw all the way in. (need to see if there is a hole in the plate.) I looked for leaks and even plugged the air bypass hose. I used rubber cement on the runner hose sleeves and Permatex on the intake gaskets. Timing is set at 7 degrees with the vacuum hose off. Any suggestions would be appreciated. Regards, Ray |
dr914@autoatlanta.com |
Oct 10 2019, 02:30 PM
914 Guru Group: Members Posts: 7,832 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we have never had any luck with using anything but the stock fuel injected cam with fuel injection. Now that you have built the engine, the only alternative is to change to megasquirt as previously stated, carbs, or change the camshaft
So I replaced the 1.8L with a SCAT 2056 long block with a Web 73 cam and 42x38 valves. They provided 4 bolt (intake) heads so I could use the 1.8 tin and carry over L-Jet system. The CR is 8.5 and I have an adjustable FPR. The injectors are stock 1.8L L-Ject. I can dial in the idle AFR easily but I get rich 9.0 AFR on very light tip in. I also go lean at higher speeds (>4000). I suspect the static is set too high on the AFM. Any suggestions? |
djway |
Oct 10 2019, 02:53 PM
Have you checked the condition of your potentiometer. Partial throttle going lien tells me it is not adding additional fuel so the question is why. The flap could be sticky or the potentiometer is not giving a good signal at partial throttle. Lean at idle should not be that bad. I have read about guys trying to get above 15 on the freeway. Heat becomes a problem when lean but unless you’re at idle for long periods of time I would not think that would be a problem.
rbzymek |
Oct 10 2019, 04:41 PM
Have you checked the condition of your potentiometer. Partial throttle going lien tells me it is not adding additional fuel so the question is why. The flap could be sticky or the potentiometer is not giving a good signal at partial throttle. Lean at idle should not be that bad. I have read about guys trying to get above 15 on the freeway. Heat becomes a problem when lean but unless you’re at idle for long periods of time I would not think that would be a problem. It actually goes rich at part throttle. I just checked to AFM voltage output and it appears to be a smooth progression. |
rbzymek |
Oct 10 2019, 05:26 PM
Have you checked the condition of your potentiometer. Partial throttle going lien tells me it is not adding additional fuel so the question is why. The flap could be sticky or the potentiometer is not giving a good signal at partial throttle. Lean at idle should not be that bad. I have read about guys trying to get above 15 on the freeway. Heat becomes a problem when lean but unless you’re at idle for long periods of time I would not think that would be a problem. It actually goes rich at part throttle. I just checked to AFM voltage output and it appears to be a smooth progression. George, I was given the impression earlier on that the Web 73 was not a carb cam and that it would work well on a 2056 and L-Jet. I really do not want to do carbs so I guess I will need to do the best I can with what I have. I'm trying to ignore that sinking feeling in my stomach. I'm sure you know what you are talking about. Regards, Ray |
djway |
Oct 10 2019, 06:29 PM
Close down your AFM bypass screw, it should Richen it up at idle then tighten your spring slightly to get your wide open throttle at the right point assuming your fifth injector is working properly.
rbzymek |
Oct 10 2019, 07:12 PM
Close down your AFM bypass screw, it should Richen it up at idle then tighten your spring slightly to get your wide open throttle at the right point assuming your fifth injector is working properly. I will try again next week. I need to demo a kitchen at the cottage this weekend. |
ClayPerrine |
Oct 10 2019, 08:52 PM
When trying to get the old tired 1.8 to run I just jumped on the freeway while watching the gauge under load then at cruise. I would get off the freeway and adjust the spring pressure then hop back on the freeway. I kept doing it until the numbers looked acceptable. In my case it was dumping too much fuel so I tightened the spring. Good plan. I have some FJ707 injectors on order which are replacements for 2.0 912 with L-Jet. I also have a fuel pressure regulator coming which is supposed to be for a 1.8 914 which should be 35 psi. All of the other FPR's I purchased are 40-42 psi. I will install the correct parts and give it a try. Clay, I installed the FJ707 General injectors and the Beck Arnley 158-0073 FPR both of which reference a 2.0L 912 engine. Engine off pushing the fuel flap I get 41 psi on the gauge. It shows about 34 psi gauge at idle with the vacuum compensation. After a good warm up run I adjusted the AFM to get 13.5 at idle and about 12- 12.5 at WOT. My RPM limit is 4000 RPM unlit after break in. The throttle body is a 45mm bus unit. The bad news is that I get 8.5 to 10.5 AFR at part throttle tip in with some rich misfire. Heavy crowd is 13-13.5. If I tighten the AFM then I get 15-18 AFR at idle---no good. I think the fuel pressure is too high but this is about the third FPR that I have tried. Another issue is that I cannot get the idle below 1200 even with the TB screw all the way in. (need to see if there is a hole in the plate.) I looked for leaks and even plugged the air bypass hose. I used rubber cement on the runner hose sleeves and Permatex on the intake gaskets. Timing is set at 7 degrees with the vacuum hose off. Any suggestions would be appreciated. Regards, Ray The fuel pressure is a little high. What fuel pump are you using? Also, you might want to try an AFM that has not been opened up. And also replace the gaskets in the oil filler cap. If they are bad,they will cause a false air issue, and make the car run bad. If someone that didn't know any better changed the AFM to compensate for the bad oil cap seals, you can get all kinds of screwy mixtures. Clay |
porschetub |
Oct 10 2019, 09:43 PM
When trying to get the old tired 1.8 to run I just jumped on the freeway while watching the gauge under load then at cruise. I would get off the freeway and adjust the spring pressure then hop back on the freeway. I kept doing it until the numbers looked acceptable. In my case it was dumping too much fuel so I tightened the spring. Good plan. I have some FJ707 injectors on order which are replacements for 2.0 912 with L-Jet. I also have a fuel pressure regulator coming which is supposed to be for a 1.8 914 which should be 35 psi. All of the other FPR's I purchased are 40-42 psi. I will install the correct parts and give it a try. Clay, I installed the FJ707 General injectors and the Beck Arnley 158-0073 FPR both of which reference a 2.0L 912 engine. Engine off pushing the fuel flap I get 41 psi on the gauge. It shows about 34 psi gauge at idle with the vacuum compensation. After a good warm up run I adjusted the AFM to get 13.5 at idle and about 12- 12.5 at WOT. My RPM limit is 4000 RPM unlit after break in. The throttle body is a 45mm bus unit. The bad news is that I get 8.5 to 10.5 AFR at part throttle tip in with some rich misfire. Heavy crowd is 13-13.5. If I tighten the AFM then I get 15-18 AFR at idle---no good. I think the fuel pressure is too high but this is about the third FPR that I have tried. Another issue is that I cannot get the idle below 1200 even with the TB screw all the way in. (need to see if there is a hole in the plate.) I looked for leaks and even plugged the air bypass hose. I used rubber cement on the runner hose sleeves and Permatex on the intake gaskets. Timing is set at 7 degrees with the vacuum hose off. Any suggestions would be appreciated. Regards, Ray The fuel pressure is a little high. What fuel pump are you using? Also, you might want to try an AFM that has not been opened up. And also replace the gaskets in the oil filler cap. If they are bad,they will cause a false air issue, and make the car run bad. If someone that didn't know any better changed the AFM to compensate for the bad oil cap seals, you can get all kinds of screwy mixtures. Clay double post,sorry. |
Lo-Fi Version | Time is now: 4th May 2024 - 01:13 AM |
