Fluid on the floor: What could it be?, (time to take a brake?)Slight mystery upon returning from Okteenerfest |
DRPHIL914 |
Oct 6 2019, 09:11 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
After returning from Okteenerfest the car sat a couple weeks, and after taking it to Cars and coffee I parked it again but backed in and a few days later pulled out and noticed 2 small puddles , front at rear- cleaned it up them parked the car , then a few days later checked again and it’s for sure under front.
I was initially worried that I had a front crank seal when I thought it was from the back, and I am releaved that it’s not from the motor, I did all that last year and am proud to say it’s been a leak free motor since then, and I didn’t want to pull the motor or trans. BUT this is brake fluid, and I can’t really explain why this would suddenly spring A leak (IMG:style_emoticons/default/confused24.gif) . I replaced all brake lines and the 19mm master cylinder about 3-4 years ago, no leaks no issues since then. And I don’t have loss of pressure on brakes so I am assuming it’s the supply line so I guess I will be pulling the belly pan to investigate. Will post more info when I get a look just wonder why just now? I know the washer is there under the supply line connection, just weird this started now??? Phil |
bbrock |
Oct 6 2019, 09:43 AM
What MC did you install? There were a small number in the first batch of MCs from 914Rubber that had a problem with the welch plug on top leaking. That area isn't under pressure but can slowly weep fluid. They test for it now so newer ones should be fine. I repressed the welch plug on mine and then filled the recess on top with JB Weld just for extra measure. Car has been sitting for months with no drips.
DRPHIL914 |
Oct 6 2019, 09:49 AM
What MC did you install? There were a small number in the first batch of MCs from 914Rubber that had a problem with the welch plug on top leaking. That area isn't under pressure but can slowly weep fluid. They test for it now so newer ones should be fine. I repressed the welch plug on mine and then filled the recess on top with JB Weld just for extra measure. Car has been sitting for months with no drips. It’s a 19mm 911 mc I bought from PMB when I got all my new hard lines and soft lines as well, same time that I did the 5-lug conversion- i did have an issue during install getting the supply line seated but once it popped into place it had been dry- I did not put in new supply line so maybe that the issue now? I home it’s not complicated it was a lot of brake fluid and the reservoir is pretty low. Btw I’m not sure but what should I be putting in, just DOT3?? This is clean no blue tinting to it |
Lo-Fi Version | Time is now: 25th April 2024 - 06:34 PM |
