Fluid on the floor: What could it be?, (time to take a brake?)Slight mystery upon returning from Okteenerfest |
DRPHIL914 |
Oct 6 2019, 09:11 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
After returning from Okteenerfest the car sat a couple weeks, and after taking it to Cars and coffee I parked it again but backed in and a few days later pulled out and noticed 2 small puddles , front at rear- cleaned it up them parked the car , then a few days later checked again and it’s for sure under front.
I was initially worried that I had a front crank seal when I thought it was from the back, and I am releaved that it’s not from the motor, I did all that last year and am proud to say it’s been a leak free motor since then, and I didn’t want to pull the motor or trans. BUT this is brake fluid, and I can’t really explain why this would suddenly spring A leak (IMG:style_emoticons/default/confused24.gif) . I replaced all brake lines and the 19mm master cylinder about 3-4 years ago, no leaks no issues since then. And I don’t have loss of pressure on brakes so I am assuming it’s the supply line so I guess I will be pulling the belly pan to investigate. Will post more info when I get a look just wonder why just now? I know the washer is there under the supply line connection, just weird this started now??? Phil |
rjames |
Oct 6 2019, 04:26 PM
I'm made of metal Group: Members Posts: 3,911 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Someone else can correct me if I’ve got this wrong, ...
If you’re not sure if you are currently running dot3 or dot4, you can safely use dot4. Use Dot5 only if that’s what you have in it now. |
Lo-Fi Version | Time is now: 20th April 2024 - 03:42 AM |
