Fluid on the floor: What could it be?, (time to take a brake?)Slight mystery upon returning from Okteenerfest |
DRPHIL914 |
Oct 6 2019, 09:11 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
After returning from Okteenerfest the car sat a couple weeks, and after taking it to Cars and coffee I parked it again but backed in and a few days later pulled out and noticed 2 small puddles , front at rear- cleaned it up them parked the car , then a few days later checked again and it’s for sure under front.
I was initially worried that I had a front crank seal when I thought it was from the back, and I am releaved that it’s not from the motor, I did all that last year and am proud to say it’s been a leak free motor since then, and I didn’t want to pull the motor or trans. BUT this is brake fluid, and I can’t really explain why this would suddenly spring A leak (IMG:style_emoticons/default/confused24.gif) . I replaced all brake lines and the 19mm master cylinder about 3-4 years ago, no leaks no issues since then. And I don’t have loss of pressure on brakes so I am assuming it’s the supply line so I guess I will be pulling the belly pan to investigate. Will post more info when I get a look just wonder why just now? I know the washer is there under the supply line connection, just weird this started now??? Phil |
Mikey914 |
Oct 8 2019, 10:38 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
No fluid on the bottom of the cylinder is indicative of a leak internal to the unit. There is some bleed through on the edges, but my money is the pedal cluster. which hopefully hasn't been soaking in brake fluid. I'm sure Bruce can attest to the damage of brake fluid on the many pedal clusters he has seen.
DRPHIL914 |
Oct 9 2019, 07:11 AM
No fluid on the bottom of the cylinder is indicative of a leak internal to the unit. There is some bleed through on the edges, but my money is the pedal cluster. which hopefully hasn't been soaking in brake fluid. I'm sure Bruce can attest to the damage of brake fluid on the many pedal clusters he has seen. thanks for the info, I took a look at the video on the install, and I do think I like the idea of getting rid of having just a grommet. sucks that I have a MC that was installed less than 5 years ago and here its leaking this bad. That seal should not have failed this soon. I have 4 vehicles that are 13-15 years old that have not had to have a master cylinder replaced. in fact the last one on the 914 was replaced it was 20 years old and had been sitting, but this should not have failed so soon. will be placing my order for the new MC today - already did all the hard and soft lines when I did my suspension and that MC , all else look good. but I have to do a lot of clean up to get the fluid out, I probably should pull my pedal assembly- it was rebuilt back 5 years ago, but should I get one with new brass bushings etc? - Phil |
Lo-Fi Version | Time is now: 20th April 2024 - 02:48 AM |
