Fluid on the floor: What could it be?, (time to take a brake?)Slight mystery upon returning from Okteenerfest |
DRPHIL914 |
Oct 6 2019, 09:11 AM
Dr. Phil Group: Members Posts: 5,756 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
After returning from Okteenerfest the car sat a couple weeks, and after taking it to Cars and coffee I parked it again but backed in and a few days later pulled out and noticed 2 small puddles , front at rear- cleaned it up them parked the car , then a few days later checked again and it’s for sure under front.
I was initially worried that I had a front crank seal when I thought it was from the back, and I am releaved that it’s not from the motor, I did all that last year and am proud to say it’s been a leak free motor since then, and I didn’t want to pull the motor or trans. BUT this is brake fluid, and I can’t really explain why this would suddenly spring A leak (IMG:style_emoticons/default/confused24.gif) . I replaced all brake lines and the 19mm master cylinder about 3-4 years ago, no leaks no issues since then. And I don’t have loss of pressure on brakes so I am assuming it’s the supply line so I guess I will be pulling the belly pan to investigate. Will post more info when I get a look just wonder why just now? I know the washer is there under the supply line connection, just weird this started now??? Phil |
dr914@autoatlanta.com |
Oct 9 2019, 08:31 AM
914 Guru Group: Members Posts: 7,806 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes master cylinder has failed. As much trouble as they are to replace I would purchase a new fte or ate cylinder and install after cleaning up the pedal cluster area of brake fluid and resultant debris and bleed thoroughly with ate brake fluid. The 19mm master cylinder is not that expensive can be bought for 220 at any of the usual suppliers, and is well worth it. 914 17mm has been discontinued
Lo-Fi Version | Time is now: 17th April 2024 - 06:36 PM |
