Fluid on the floor: What could it be?, (time to take a brake?)Slight mystery upon returning from Okteenerfest |
DRPHIL914 |
Oct 6 2019, 09:11 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
After returning from Okteenerfest the car sat a couple weeks, and after taking it to Cars and coffee I parked it again but backed in and a few days later pulled out and noticed 2 small puddles , front at rear- cleaned it up them parked the car , then a few days later checked again and it’s for sure under front.
I was initially worried that I had a front crank seal when I thought it was from the back, and I am releaved that it’s not from the motor, I did all that last year and am proud to say it’s been a leak free motor since then, and I didn’t want to pull the motor or trans. BUT this is brake fluid, and I can’t really explain why this would suddenly spring A leak (IMG:style_emoticons/default/confused24.gif) . I replaced all brake lines and the 19mm master cylinder about 3-4 years ago, no leaks no issues since then. And I don’t have loss of pressure on brakes so I am assuming it’s the supply line so I guess I will be pulling the belly pan to investigate. Will post more info when I get a look just wonder why just now? I know the washer is there under the supply line connection, just weird this started now??? Phil |
DRPHIL914 |
Oct 18 2019, 09:40 AM
I would assume this could be rebuilt and a new seal installed? if so how hard is this to do? is this something you do Mark? or PMB?
it is a 19mm ATC 911 MC |
76-914 |
Oct 18 2019, 10:19 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,490 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I would assume this could be rebuilt and a new seal installed? if so how hard is this to do? is this something you do Mark? or PMB? it is a 19mm ATC 911 MC Good luck finding the kit for it. MC kits were readily available for all cars in the 70's & 80's. Also. this isn't something you'd want to tackle w/o some knowledge of how to do it. First you had to determine if it was rebuildable. If the bore was pitted or scratched the MC was junk and red tagged. That being said, I rebuilt a pitted MC on my 56 Chevy a couple of times in a 2 week period just to keep me on the road until I could buy a rebuilt one. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 11:38 PM |
