Fluid on the floor: What could it be?, (time to take a brake?)Slight mystery upon returning from Okteenerfest |
DRPHIL914 |
Oct 6 2019, 09:11 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
After returning from Okteenerfest the car sat a couple weeks, and after taking it to Cars and coffee I parked it again but backed in and a few days later pulled out and noticed 2 small puddles , front at rear- cleaned it up them parked the car , then a few days later checked again and it’s for sure under front.
I was initially worried that I had a front crank seal when I thought it was from the back, and I am releaved that it’s not from the motor, I did all that last year and am proud to say it’s been a leak free motor since then, and I didn’t want to pull the motor or trans. BUT this is brake fluid, and I can’t really explain why this would suddenly spring A leak (IMG:style_emoticons/default/confused24.gif) . I replaced all brake lines and the 19mm master cylinder about 3-4 years ago, no leaks no issues since then. And I don’t have loss of pressure on brakes so I am assuming it’s the supply line so I guess I will be pulling the belly pan to investigate. Will post more info when I get a look just wonder why just now? I know the washer is there under the supply line connection, just weird this started now??? Phil |
DRPHIL914 |
Oct 18 2019, 09:40 AM
I would assume this could be rebuilt and a new seal installed? if so how hard is this to do? is this something you do Mark? or PMB?
it is a 19mm ATC 911 MC |
Mikey914 |
Oct 18 2019, 10:30 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I would assume this could be rebuilt and a new seal installed? if so how hard is this to do? is this something you do Mark? or PMB? it is a 19mm ATC 911 MC There were kits in the day. However, it is up to the re builder to get it right, and there are some issues that can't be fixed. Not really worth the time an energy to rebuild as many are too far gone. Just out of curiosity is it an ATE? Should be a stamp on it. mark |
Lo-Fi Version | Time is now: 18th April 2024 - 10:38 PM |
