Is this a big issue?, Engine bracket |
RolinkHaus |
Oct 7 2019, 05:08 PM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
Noticed the engine bracket is bent. Not to worry, the engine will probably be dropped to replace and remove the oil cooler. Good times.... (IMG:style_emoticons/default/hissyfit.gif)
Mikey914 |
Oct 7 2019, 10:48 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The "mount" is not bent. just the bolt. If you run over a speed bump that has some height you will do this again. Jack it up. unbolt and go to your local hardware store. should be about $3 give or take.
I do have some of Bruce's kits but really it's only one bolt. put the bling on it when you drop and clean. |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:37 AM |
