Is this a big issue?, Engine bracket |
RolinkHaus |
Oct 7 2019, 05:08 PM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
Noticed the engine bracket is bent. Not to worry, the engine will probably be dropped to replace and remove the oil cooler. Good times.... (IMG:style_emoticons/default/hissyfit.gif)
RolinkHaus |
Oct 8 2019, 04:16 AM
Are these mounts interchangeable with my set up?
Maltese Falcon |
Oct 8 2019, 05:12 AM
Advanced Member Group: Members Posts: 4,636 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Are these mounts interchangeable with my set up? Pictured mount you show here would be for the 1970-72 model years, as the Outboard - Located style. These attach at the engine bar Left and Right ends, and then the engine is attached (solid) directly to the center of this bar.. 1973-up style is what you are running; with solid mounted Outboard...and the different style neoprene/ studded mounts (center of bar) that are shown in prev post. The latter is required in your model year...and a new bolt ¡ |
Lo-Fi Version | Time is now: 2nd May 2024 - 11:01 AM |
