Is this a big issue?, Engine bracket |
RolinkHaus |
Oct 7 2019, 05:08 PM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
Noticed the engine bracket is bent. Not to worry, the engine will probably be dropped to replace and remove the oil cooler. Good times.... (IMG:style_emoticons/default/hissyfit.gif)
914Sixer |
Oct 7 2019, 06:49 PM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Get one of Bruce Stone's HD brackets and not worry about it again.
Olympic 914 |
Oct 8 2019, 09:19 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Get one of Bruce Stone's HD brackets and not worry about it again. Not to dis Bruce's products but it is not a bad idea to have a weak link there. If you hit something its better to have the bolt bend or the U bracket bend. you can easily hammer the U bracket back into shape or replace the bolt. you don't want to strengthen the bracket and have the motor mount welded to the body bend instead. JMHO Don't be surprised if the bolts break off. just apply some heat and drive the piece out. |
bdstone914 |
Oct 8 2019, 02:16 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Get one of Bruce Stone's HD brackets and not worry about it again. Not to dis Bruce's products but it is not a bad idea to have a weak link there. If you hit something its better to have the bolt bend or the U bracket bend. you can easily hammer the U bracket back into shape or replace the bolt. you don't want to strengthen the bracket and have the motor mount welded to the body bend instead. JMHO Don't be surprised if the bolts break off. just apply some heat and drive the piece out. My brackets are only a few thousand thicker than original. The bolts will still bend when hit. Mist if those brackets are bent from lifting the car from the engine bar. That's why I remade them. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 2nd May 2024 - 07:08 PM |
