Is this a big issue?, Engine bracket |
RolinkHaus |
Oct 7 2019, 05:08 PM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
Noticed the engine bracket is bent. Not to worry, the engine will probably be dropped to replace and remove the oil cooler. Good times.... (IMG:style_emoticons/default/hissyfit.gif)
bdstone914 |
Oct 8 2019, 02:20 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Noticed the engine bracket is bent. Not to worry, the engine will probably be dropped to replace and remove the oil cooler. Good times.... (IMG:style_emoticons/default/hissyfit.gif) Both the bolt and bracket are probably bent. When you replace them insert the bolt from the bottom. When the car bottoms out it prevents the threads from damage making removal difficult. Bruce |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:24 AM |
