Is this a big issue?, Engine bracket |
RolinkHaus |
Oct 7 2019, 05:08 PM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
Noticed the engine bracket is bent. Not to worry, the engine will probably be dropped to replace and remove the oil cooler. Good times.... (IMG:style_emoticons/default/hissyfit.gif)
Literati914 |
Oct 9 2019, 11:24 AM
Senior Member Group: Members Posts: 1,443 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Are these mounts interchangeable with my set up? Pictured mount you show here would be for the 1970-72 model years, as the Outboard - Located style. These attach at the engine bar Left and Right ends, and then the engine is attached (solid) directly to the center of this bar.. Does anyone have a picture of these installed ? I keep reading these go on the ends on early cars but have never seen it.. and now I've got a '72 I'm messing with. TIA. |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:23 AM |
