No power to injectors again!, Got spark, gas, at a total loss |
surfdogskier |
Oct 7 2019, 06:22 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
Oh my gosh!!!! She is back to doing this same thing all over again. I finally got her running . She ran fine one evening, parked her. Next day she would not start. No power to the injectors. I got spark. I got gas in the lines. Fuel pump works like it should. I took the distributor out and cleaned the trigger points to see if that would help. All wires are connected. MPS connected. All vacuum lines connected. I bought a noid light set up and they are definitely not getting power.
What else could it be? Something on the relay board? Bad relay? This car is driving me insane. I am about to go duel carbs and drop this piece of **** fuel injection if I can't get this thing running. |
surfdogskier |
Oct 8 2019, 07:36 PM
I do want to mention. If she sets for a little while and I go to crank her, she will try to turn over. It is like she is getting a spitter of gas. It is much like if you spray starting fluid and it hits the plugs except it doesn't last but a second or so.
I am going to check my trigger points again like I mentioned. One thing also when I was going through this before is the MPS. If it was touching metal it seems like, the car would not start. I would move it and she would start. I also noticed the plug can go in both ways but only one way allowed it to start. Now I have her mounted where she suppose to go but I just wonder if that could be my issue. Anyway to check that? Do these things go bad? |
dr914@autoatlanta.com |
Oct 9 2019, 03:03 PM
914 Guru Group: Members Posts: 7,856 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
probably two of the injectors spitting a bit of gas when the key is turned on. You can turn the key off on off on off on off on and then hit it and if the car starts and dies, you know that the two of the trigger points are sending a signal.
By the way, will the car run continually if starting fluid or gas is sprayed into the throttle body? I do want to mention. If she sets for a little while and I go to crank her, she will try to turn over. It is like she is getting a spitter of gas. It is much like if you spray starting fluid and it hits the plugs except it doesn't last but a second or so. I am going to check my trigger points again like I mentioned. One thing also when I was going through this before is the MPS. If it was touching metal it seems like, the car would not start. I would move it and she would start. I also noticed the plug can go in both ways but only one way allowed it to start. Now I have her mounted where she suppose to go but I just wonder if that could be my issue. Anyway to check that? Do these things go bad? |
surfdogskier |
Oct 9 2019, 06:23 PM
I is like it has a drop of gas to tease it. I tried that with the starting fluid and it didn't go so well. Ended up catching my engine on fire for a bit. Fortunately nothing was really harmed other than some singhed wires which I replaced.
Lo-Fi Version | Time is now: 14th May 2024 - 02:43 PM |
