No power to injectors again!, Got spark, gas, at a total loss |
surfdogskier |
Oct 7 2019, 06:22 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
Oh my gosh!!!! She is back to doing this same thing all over again. I finally got her running . She ran fine one evening, parked her. Next day she would not start. No power to the injectors. I got spark. I got gas in the lines. Fuel pump works like it should. I took the distributor out and cleaned the trigger points to see if that would help. All wires are connected. MPS connected. All vacuum lines connected. I bought a noid light set up and they are definitely not getting power.
What else could it be? Something on the relay board? Bad relay? This car is driving me insane. I am about to go duel carbs and drop this piece of **** fuel injection if I can't get this thing running. |
Mikey914 |
Oct 7 2019, 06:27 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
It injection is the best way to go if you can keep it running. What motor?
All 4 I suspect trigger points. Factory spacing is 23mm |
surfdogskier |
Oct 7 2019, 06:52 PM
It injection is the best way to go if you can keep it running. What motor? All 4 I suspect trigger points. Factory spacing is 23mm Sorry about that. 1.7. It is all four. I pulled the trigger points and cleaned them. The 3 wires look to be in good condition and the plug. |
Lo-Fi Version | Time is now: 28th April 2024 - 04:14 PM |
