No power to injectors again!, Got spark, gas, at a total loss |
surfdogskier |
Oct 7 2019, 06:22 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
Oh my gosh!!!! She is back to doing this same thing all over again. I finally got her running . She ran fine one evening, parked her. Next day she would not start. No power to the injectors. I got spark. I got gas in the lines. Fuel pump works like it should. I took the distributor out and cleaned the trigger points to see if that would help. All wires are connected. MPS connected. All vacuum lines connected. I bought a noid light set up and they are definitely not getting power.
What else could it be? Something on the relay board? Bad relay? This car is driving me insane. I am about to go duel carbs and drop this piece of **** fuel injection if I can't get this thing running. |
JeffBowlsby |
Oct 8 2019, 03:51 PM
914 Wiring Harnesses Group: Members Posts: 8,484 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Yes to the first question. No to the second.
Slide the grey plastic cover off the ECU, and pull off the plug. You may be surprised at how easy it is once you do it the first time. |
surfdogskier |
Oct 8 2019, 05:41 PM
Yes to the first question. No to the second. Slide the grey plastic cover off the ECU, and pull off the plug. You may be surprised at how easy it is once you do it the first time. Thanks for clarifying. I looked and thought I had to pry all those clips up and then bend them back.....I will go from there and post back. |
Lo-Fi Version | Time is now: 28th April 2024 - 05:41 PM |
