3rd to 2nd = GRIND!, 1st to 2nd to 3rd to 4th to 5th AOK |
ctc911ctc |
Oct 8 2019, 07:21 PM
Senior Member Group: Members Posts: 891 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Hello Again All Teeners,
After 100 little projects I have the silver bullet (silver '74 2.0) back on the road, first time it has been registered since 1984. Runs great, needs paint and perhaps a tranny freshening?????? I replaced all of the guide nylon bushings and re-centered the stick shift. However, when down-shifting 3rd to 2nd is horrible, (GRIND!) better when I double shift. First to second is ok, though at times if I am too aggressive it too will grind. WHATS NEXT ON MY LIST????? remove the 1st and reverse section of the tranny? Complete rebuild? Can hardly wait! Many thanks for all of the great guidance over the years. CTC911CTC |
rhodyguy |
Oct 9 2019, 07:52 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
If you just push the lever forward going from 1st to 2nd the trans should jump into the neutral plane. This is where the dentension plate and springs in the shifter assem come in to play. Then you should be able to engage 2nd cleanly. If you want to bang gears buy a Mustang.
ctc911ctc |
Oct 9 2019, 08:38 AM
I remember driving a new 914 in 73, the '73 tranny was very crisp and the linkage "jump" you mentioned was really apparent.
The 'jump' on the car we are working on is much less. All of the bushings are lubed and slide easy, I have not touched the springs in the shift assembly. Might new springs help? Thanks for the guidance!! - Mustang? Really? grin! If you just push the lever forward going from 1st to 2nd the trans should jump into the neutral plane. This is where the dentension plate and springs in the shifter assem come in to play. Then you should be able to engage 2nd cleanly. If you want to bang gears buy a Mustang. |
Lo-Fi Version | Time is now: 26th April 2024 - 06:19 AM |
