Rattle in shifting mechanism |
andreic |
Oct 9 2019, 08:12 AM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
Hello,
I have a 1972 with the early (tail) shifter mechanism. The transmission shifts very well after I replaced all the bushings and adjusted the shifter. However, in second, third, fourth, and fifth gears, as I accelerate through 1400 rpm there is a loud rattle that seems to come through the firewall. I believe it must be coming from the connection between the front shifter bar (the one that goes through the firewall) and the rear one. Both plastic balls at that connection were recently replaced in the shifting mechanism, but that part of the shifter still does not feel tight. The balls used were the black plastic ones supplied by Pelican. Does anyone have any experience with these? Is there any other supplier of the plastic balls? If not, is there anything else I can do to eliminate the rattle there? Thanks, Andrei. |
rhodyguy |
Oct 10 2019, 09:16 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,071 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Did you replace the bushing in the carrier behind the shifter? In 1&r the linkage is under a side load.
Lo-Fi Version | Time is now: 4th May 2024 - 05:26 AM |
