Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
mepstein |
Oct 9 2019, 11:01 AM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Just say NO to KYB struts. Spend the money on Bilsteins. You wont be dissapointed.
Always do new brake soft lines if you don't know or cant remember when they were last done. |
914_teener |
Oct 9 2019, 11:51 AM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Hope your budget is $1800.
Might as well do adjustable perches for the Billy's. Do the bushings yourself and the alignment. You will learn a lot and it's not that hard. You should check and repack the CV's while you are there and with all that said may never have to touch the rear suspension ever....at least it depends how old you are and have the car. Good wrenching. |
SirAndy |
Oct 9 2019, 12:02 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Tbrown4x4 |
Oct 9 2019, 05:13 PM
Senior Member Group: Members Posts: 702 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
PMB is the benchmark for caliper rebuilds, but I had good luck rebuilding my own with caliper paint and parts bought from PMB. Eric can also just plate your caliper halves if you take them apart first. Change out the brake hoses too.
No KYBs! They're cheaper for a reason. My Koni reds (rear shocks) started leaking, so I pulled the nice looking KYB's off my parts car. They had Weltmeister 140lb springs on them and the car rode like it had no suspension at all. I put new Koni adjustable shocks (with 3 clicks from full soft) in the 140 springs and I really like the ride. Firm, but compliant. I put 100 miles a day on I-5, and still have my kidneys. My car doesn't have sway bars. I only have experience with rubber suspension bushings. I would probably use original type rubber or maybe a little firmer for a daily. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-17338-1570663066.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-17338-1570663066.2.jpg) |
rhodyguy |
Oct 9 2019, 05:31 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Better off spending more now rather than might being unhappy later. Deduct what ever you spend on KYBs from the upgrade. Koni yellows are nice due to the ex adj feature. Have a look at Paragon's site. Struts and shocks are prob one of the most rewarding tasks on a 914. 2-4 hours and you have a new car. Inspect the bushings on the tie rods.
roblav1 |
Oct 9 2019, 06:23 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
As others said, don't use KYB.
914Sixer |
Oct 10 2019, 04:22 AM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
KYB= Kill Your Back. If you want to feel every pebble on the road, stay a way from KYB.
tvdinnerbythepool |
Oct 10 2019, 07:40 AM
Awesome, thanks for the input guys.
Sounds like Koni or Bilstein for the shocks and I'll add new brake soft hoses to the list. |
tvdinnerbythepool |
Oct 10 2019, 07:41 AM
@Tbrown4x4 did I see you by the Olympia airport a few days ago? Great looking car!
Tbrown4x4 |
Oct 11 2019, 04:54 AM
I was down that way for a wedding , but we took the Wife's Focus.
Besides, if it was "great looking", it wasn't me. (IMG:style_emoticons/default/smile.gif) |
tvdinnerbythepool |
Oct 24 2019, 10:24 PM
Hey guys!
I've seen a few methods online but what is the best way to get these bushings out of the rear control arms? After much swearing, hammering and torching I finally got everything torn out and disassembled. Going to sandblast the calipers tomorrow and am awaiting parts from Pelican and 914 Rubber. Discovered much half assed work from PO much to my amusement. Finally figured out why the right wheel had so much camber than the left...no shim! Lol |
914werke |
Oct 25 2019, 12:24 AM
"I got blisters on me fingers" Group: Members Posts: 9,999 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
From that pic it looks like you may have more work ahead of you.
Having done a few of these ... the problem youll find is that your pivot shafts are going to be pretty rusty & corroded where the OE vulcanized rubber was attached. |
Tbrown4x4 |
Oct 25 2019, 05:01 AM
I'm reading that you are blasting the calipers, so I assume you're painting them. Make sure no blast media gets into the bleeder hole (or any other caliper passages for that matter). I had to run a wire through mine to clear out some grit. Also, Rustoleum discontinued the silver caliper paint that I used. You're stuck with black or red. VHT, Eastwood and Duplicolor caliper paints are only good for 500-600 degrees, whereas the Rustoleum paints are good for 900. I also used the 2000 deg primer, but the Rustoleum Rep said the caliper paint is direct to metal. I've got over 3000 miles of driving on mine with no discoloration of the silver.
Also clean out any paint overspray where brake fluid will be with solvent. |
mepstein |
Oct 25 2019, 06:13 AM
Hey guys! I've seen a few methods online but what is the best way to get these bushings out of the rear control arms? After much swearing, hammering and torching I finally got everything torn out and disassembled. Going to sandblast the calipers tomorrow and am awaiting parts from Pelican and 914 Rubber. Discovered much half assed work from PO much to my amusement. Finally figured out why the right wheel had so much camber than the left...no shim! Lol Either heat from a torch or a press. I’ve done both. Torch is the fastest. Heat until you get some smoke and then pry out with a screwdriver. Same with the rubber a arm bushings. |
tvdinnerbythepool |
Oct 25 2019, 09:59 AM
tvdinnerbythepool |
Oct 25 2019, 10:49 AM
1 down! Took about 40 minutes with heat and press.
A little pitting on one end but should lean up nicely Attached thumbnail(s) |
mepstein |
Oct 25 2019, 11:17 AM
Mine took 5-10 minutes each side but I really laid in the heat. I was blasting and powder coating after so I didn’t worry about the paint. I was thinking about building up the pits with jb weld and then sanding smooth but I haven’t done it yet. I’m not sure it makes any difference.
914werke |
Oct 25 2019, 11:42 AM
(IMG:style_emoticons/default/sad.gif) Mmmm IDK... I chuck them up in the lathe & take a mil off of them to get down to clean smooth metal before reusing.
TonyA |
Oct 25 2019, 01:31 PM
Nachmal Group: Members Posts: 460 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Like that operating room clean look of your shop. . |
Lo-Fi Version | Time is now: 25th April 2024 - 11:51 AM |
