Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
DRPHIL914 |
Nov 23 2019, 02:34 PM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Looks nice , did you put the spring retainer clip at the top space?
tvdinnerbythepool |
Nov 23 2019, 03:14 PM
@DRPHIL914 Hi! Not sure what that means...can you clarify?
DRPHIL914 |
Nov 23 2019, 04:47 PM
There are 6 I think slots for the retainer that holds the spring retainer clip. It looks like you are set at the very top one ( grooves on the yellow billestien shock) it ma be a bit too springy and high at that setting, at least that was my experience. Mine is at the third slot down, seems about right for height and feel, but every car is different |
jmitro |
Nov 24 2019, 02:29 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
There are 6 I think slots for the retainer that holds the spring retainer clip. It looks like you are set at the very top one ( grooves on the yellow billestien shock) it ma be a bit too springy and high at that setting, at least that was my experience. Mine is at the third slot down, seems about right for height and feel, but every car is different it also will depend on the spring rate and unloaded length of the spring. I have 140lb Weltmeisters (don't know the unloaded length) and the spring perch is on 4th notch from the bottom |
Lo-Fi Version | Time is now: 22nd May 2024 - 03:15 AM |
