Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
Tbrown4x4 |
Oct 25 2019, 05:01 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I'm reading that you are blasting the calipers, so I assume you're painting them. Make sure no blast media gets into the bleeder hole (or any other caliper passages for that matter). I had to run a wire through mine to clear out some grit. Also, Rustoleum discontinued the silver caliper paint that I used. You're stuck with black or red. VHT, Eastwood and Duplicolor caliper paints are only good for 500-600 degrees, whereas the Rustoleum paints are good for 900. I also used the 2000 deg primer, but the Rustoleum Rep said the caliper paint is direct to metal. I've got over 3000 miles of driving on mine with no discoloration of the silver.
Also clean out any paint overspray where brake fluid will be with solvent. |
Lo-Fi Version | Time is now: 4th May 2024 - 03:57 AM |
