Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
tvdinnerbythepool |
Oct 24 2019, 10:24 PM
Hey guys!
I've seen a few methods online but what is the best way to get these bushings out of the rear control arms? After much swearing, hammering and torching I finally got everything torn out and disassembled. Going to sandblast the calipers tomorrow and am awaiting parts from Pelican and 914 Rubber. Discovered much half assed work from PO much to my amusement. Finally figured out why the right wheel had so much camber than the left...no shim! Lol |
mepstein |
Oct 25 2019, 06:13 AM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Hey guys! I've seen a few methods online but what is the best way to get these bushings out of the rear control arms? After much swearing, hammering and torching I finally got everything torn out and disassembled. Going to sandblast the calipers tomorrow and am awaiting parts from Pelican and 914 Rubber. Discovered much half assed work from PO much to my amusement. Finally figured out why the right wheel had so much camber than the left...no shim! Lol Either heat from a torch or a press. I’ve done both. Torch is the fastest. Heat until you get some smoke and then pry out with a screwdriver. Same with the rubber a arm bushings. |
Lo-Fi Version | Time is now: 4th May 2024 - 07:21 AM |
