Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
mepstein |
Oct 25 2019, 11:17 AM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mine took 5-10 minutes each side but I really laid in the heat. I was blasting and powder coating after so I didn’t worry about the paint. I was thinking about building up the pits with jb weld and then sanding smooth but I haven’t done it yet. I’m not sure it makes any difference.
Lo-Fi Version | Time is now: 4th May 2024 - 09:08 AM |
