Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
tvdinnerbythepool |
Oct 25 2019, 10:49 AM
1 down! Took about 40 minutes with heat and press.
A little pitting on one end but should lean up nicely Attached thumbnail(s) |
TonyA |
Oct 25 2019, 01:31 PM
Nachmal Group: Members Posts: 460 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Like that operating room clean look of your shop. . |
Lo-Fi Version | Time is now: 4th May 2024 - 11:54 AM |
