Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
mepstein |
Nov 1 2019, 07:34 AM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’m pretty sure all the calipers had nuts for the ribe bolts and not screwed directly into the caliper. If that’s what I’m getting from your last post. I don’t think there is a source for those bolts other than used. They are pretty unusual.
bbrock |
Nov 1 2019, 08:00 AM
I’m pretty sure all the calipers had nuts for the ribe bolts and not screwed directly into the caliper. If that’s what I’m getting from your last post. I don’t think there is a source for those bolts other than used. They are pretty unusual. My car had a mix of early and late so I got a nice education on the differences. Early - Ribe star socket through bolts with nuts. Late - hex head bolts threaded into the caliper housing (no nuts). The hex head bolts may also be stamped "RIBE" on the head, so it can be a little confusing if we just call them ribe bolts. My late hex head bolts were a mix of Ribe and Verbus. As far as ease of reassembly - the REassembly is super easy. Takes just a few miutes per caliper. It is the DISassembly that can be a bitch. On a scale of 1-10, I'd say the disassembly can be anywhere from 4-9.5 depending on condition of the caliper and reassembly of a cleaned and prepped caliper an easy 2. I'd put the overall rebuild of a caliper that doesn't give you too many fits at around 5. It's a dirty and time consuming process, but not terrible until you encounter something that is seized and doesn't want to come apart. Oh, it can also be a really PITA if you send the housings to the wong pater and they come back ruined. Ask me how I know. (IMG:style_emoticons/default/headbang.gif) Send them to Eric for plating. @tvdinnerbythepool your painted calipers look really nice! Will be curious to see how they hold up. I'm impressed. |
Lo-Fi Version | Time is now: 4th May 2024 - 01:09 AM |
