Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
tvdinnerbythepool |
Nov 14 2019, 11:11 PM
Bearings are in! Going to make a threaded tool to compress the hubs in evenly like Eric Shea's video shows Got these really nice pivot arm shafts/bushings from 914rubber @mikey914 @914werke hooked me up with a replacement hub (PO destroyed one and reinstalled anyway) and some hard brake lines. CV joints re-packed and new gaskets. 1 gasket was completely missing and was throwing grease inside the control arm by the hub. Glad I caught that. Tomorrow will try and get the hubs installed and the stainless lines in and then I think I'm ready to start bolting this thing back together!! |
Lo-Fi Version | Time is now: 4th May 2024 - 05:46 AM |
