Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
914werke |
Nov 16 2019, 12:21 AM
"I got blisters on me fingers" Group: Members Posts: 10,037 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Actually when Elephant made their rods they used a standard size tube that was not metric line the OEM. The bushings they made are to go with their rod, so they don’t work well with the stock rods (and the ones I made). (IMG:style_emoticons/default/confused24.gif) why would you bother with used OE ones if you are getting new ones as part of their (elephant) kits? |
Mikey914 |
Nov 16 2019, 11:22 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Actually when Elephant made their rods they used a standard size tube that was not metric line the OEM. The bushings they made are to go with their rod, so they don’t work well with the stock rods (and the ones I made). (IMG:style_emoticons/default/confused24.gif) why would you bother with used OE ones if you are getting new ones as part of their (elephant) kits?Yes but you can't use the rubber without their shafts. It will not fit correctly as they made a non standard size. |
Lo-Fi Version | Time is now: 4th May 2024 - 12:02 AM |
