Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
tvdinnerbythepool |
Nov 23 2019, 12:54 PM
With the back pretty much wrapped up it's on to the front.
Ripped it all out and have a pretty good plan of action. New A Arm Bushings/Install Tool (914 Rubber + Ian's Video should help) Bilsteins on the way to match the rears New Rotors, Pads, Bearings, Ball-joints New Stainless soft lines Rebuilding Calipers (Rears went well so here is round 2 for me) Tie Rod Ends (Stock not turbo upgrade for me) Bought the install tool for the ball joints, got the old ones out with the air chisel in about 10 seconds surprisingly! Bushings were totally shot, out of round and a mess. Anyways, guidance as always appreciated. Have most of the parts on hand if not already shipping to me so I'm hoping to keep the momentum between trips. |
Lo-Fi Version | Time is now: 4th May 2024 - 12:14 PM |
