Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
tvdinnerbythepool |
Nov 16 2019, 07:05 PM
mepstein |
Nov 23 2019, 01:36 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Starting to see some progress and feeling like I didn't ruin everything and she may drive once more. Lol! I'm curious about the rear shafts. None of the ones I've taken apart seem to have washers on the ends of the shafts. Is that correct? Attached image(s) |
tvdinnerbythepool |
Nov 23 2019, 02:07 PM
Starting to see some progress and feeling like I didn't ruin everything and she may drive once more. Lol! I'm curious about the rear shafts. None of the ones I've taken apart seem to have washers on the ends of the shafts. Is that correct? @mepstein I put the washers on there...it just feels wierd to not! Should I take them off? Was there a reason to NOT use a washer? |
mepstein |
Nov 23 2019, 02:10 PM
Starting to see some progress and feeling like I didn't ruin everything and she may drive once more. Lol! I'm curious about the rear shafts. None of the ones I've taken apart seem to have washers on the ends of the shafts. Is that correct? @mepstein I put the washers on there...it just feels wierd to not! Should I take them off? Was there a reason to NOT use a washer? No, I'm not saying you are wrong. I put a washer there as well. I'm just wondering why Porsche didn't (IMG:style_emoticons/default/confused24.gif) |
tvdinnerbythepool |
Nov 23 2019, 03:13 PM
@mepstein I was thinking the same thing! (IMG:style_emoticons/default/confused24.gif)
mepstein |
Nov 24 2019, 12:24 PM
So I think what Porsche calls the link bearing (#5) that holds the end of the shaft in place is acting as a washer on the shaft. There is a normal washer on the end for the inner suspension console. Attached image(s) |
Lo-Fi Version | Time is now: 4th May 2024 - 01:48 PM |
