Questions for the Collective |
bkrantz |
Oct 12 2019, 09:49 PM
914 Guru Group: Members Posts: 7,766 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I would appreciate some answers and other feedback--don't be shy.
A month ago I brought home a 1973 2 liter. The car came with a COA that shows the engine and trans as original, as is the color. It has all the original performance/appearance parts, including 5 good Fuchs wheels. It was not running when I bought it, but did run earlier in the year. My initial assessment showed some minor rust and body issues, but it looked solid. Now after a month of stripping down, I have found more rust, mostly in the floor. The areas under both seats are either very thin or with some small holes, and both front floor corners have 4 inch holes. The upper fire wall behind the passenger seat has rusted through, as has the right engine shelf. The top of the hell hole has extreme scale, but no holes (until I really dug in with my chisel). And I found a couple of small holes in the inner fender where the battery tray (replaced) attaches. On the plus side, the longs are very solid and clean, inner and outer, on both sides, as is the lower fire wall where all the cable fittings attach. Other body issues: the front and rear right fenders were replaced at some time, as was the right side of the front panel (but the floor and inner right fender are original). The groove for the front trunk gasket is messed up in places, but not rusty. The rear trunk and engine lid hinge mounts are messed up. The windshield was glued and sealed with at least 4 different kinds of stuff. All the bright trim, and the bumpers, were painted black--and the front bumper looks repaired under the paint. And the black carries over with undercoat sprayed in the engine compartment, both trunks, and passenger area. Inside, the seats were recovered--not stock but look pretty good. The dash and firewall cover look good. The door cards are uncut, but somebody cut speakers into the sides of the center console. One final observation: the more I take things apart, the more ghetto repairs I find, with non-stock, mixed hardware, home-made brackets and wiring, and cheats. First question: should I continue with my plan to restore to a nice running but not 100% vintage state? I kept looking for a place to stop as things came apart, but in my quest to remove all the sketchy stuff I am approaching a bare shell. Second question: is this car worth the effort to replace the floor, patch the other rust, and straighten various bends and mis-fits? I know I will end up with a complete paint job, and replacing most of the rubber and trim. And none of this even considers the drive train. Final question: if I end up with the body shell stripped bare, what's the logical approach and order of work, considering the floor, local patching around the hell hole and fire wall, and work on the front and rear? Attached thumbnail(s) |
bkrantz |
Oct 15 2019, 08:34 PM
One more fun surprise: when pulling the fuel evap hoses, I found a fair amount of oil in one.
bbrock |
Oct 15 2019, 09:24 PM
One more fun surprise: when pulling the fuel evap hoses, I found a fair amount of oil in one. I wonder if someone mistakenly hooked up the evap hose to the oil breather. That's gross! Also, I'll pass along the same great advice I got when I started my project. Brace the door openings before starting any rust repair and get all the repairs on the structural members done before putting it on the rotisserie. It's best to repair longs and hell hole with the car level and well supported. It doesn't sound like you have any major structural issues to repair, but make sure before hanging it on a rotisserie. I'm excited to watch this build! (IMG:style_emoticons/default/popcorn[1].gif) |
bkrantz |
Oct 16 2019, 08:37 PM
[/quote] Also, I'll pass along the same great advice I got when I started my project. Brace the door openings before starting any rust repair and get all the repairs on the structural members done before putting it on the rotisserie. It's best to repair longs and hell hole with the car level and well supported. It doesn't sound like you have any major structural issues to repair, but make sure before hanging it on a rotisserie. I'm excited to watch this build! (IMG:style_emoticons/default/popcorn[1].gif) [/quote] Thanks--that's my plan. Now to start a rebuild thread. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:27 AM |
