How to test MPS, I think it is not working |
surfdogskier |
Oct 14 2019, 06:03 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
So before I go ballistic and switch over to dual carbs, I just want to check one more thing. The only thing I can see that I see could be the reason my injectors are not firing is due to the MPS.
Is there a way I can check to see if the MPS is working properly using an ohm meter or other device? I see the wire on the MPS has the numbers 7,8, 10, 15. I would like to check the continuity of these wires as well. Where is the other end locate? Thanks |
dr914@autoatlanta.com |
Oct 15 2019, 10:37 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
do not give up! If you send us your control unit and manifold pressure sensor we will check for free, do it all of the time for customers
Lo-Fi Version | Time is now: 19th May 2024 - 05:41 AM |
