Question about SSI models..., 1.7 vs 2.0 |
BuddyV |
Oct 14 2019, 07:07 PM
Robert Group: Members Posts: 552 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
So.... I see that the rear exit plumbing on the 1.7/1.8 SSI exchanger model does an "S-Curve" in the upward direction...… making it impossible to attach a stock 2.0 muffler.
The 2.0 SSI exchangers have more of a STRAIGHT design to the exit flanges. Question: Other than the shape of the exit flanges, is there any difference in the internals of the two designs? Does the 2.0 have larger diameter tubing? Better flow?? Or is the only difference the rear flange design? I just realized that I have 1.7/1.8 SSI exchangers on my 2056 motor..... I realized this when I attempted to attach my (new to me) stock 2.0 muffler (IMG:style_emoticons/default/mad.gif) Looking to learn before I start removing/swapping/customizing/ruining (IMG:style_emoticons/default/beerchug.gif) |
Oct 14 2019, 07:09 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Same ID/OD so they flow the same. Just different in the exit direction. and need a different hanger and muffler.
VaccaRabite |
Oct 15 2019, 09:43 AM
En Garde! Group: Admin Posts: 13,423 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The less bends the better in terms of airflow.
But I bet not even a dyno would be able to tell the difference in airflow between the 1.7 and 2.0. Zach |
mb911 |
Oct 15 2019, 02:03 PM
914 Guru Group: Members Posts: 6,802 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Height of the inlets and flange spacing are the biggest difference
Olympic 914 |
Oct 16 2019, 07:45 AM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Check the classifieds Someone has a WTB for a 2.0 muffler.
Then you can start looking for a 1.7/1,8 muffler to match your SSI HE You will also need the 1.7/1.8 bracket, if you don't already have that part. |
rhodyguy |
Oct 16 2019, 07:50 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
And the correct HE to muffler gaskets. 2.0 style vs 1.7/1.8.
johnhora |
Oct 16 2019, 08:27 AM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
As mentioned above the real difference is in the pipe exit at the rear.
Which equates to a different hanger and muffler. This may help. |
Triaddave |
Oct 19 2019, 04:15 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
TheCabinetmaker |
Oct 20 2019, 12:27 PM
The only numbers that matter for the 75/76, are the horse power numbers that drop cause of the exhaust.
Triaddave |
Oct 20 2019, 01:34 PM
Lo-Fi Version | Time is now: 22nd April 2024 - 11:32 PM |
