Who has Dual 34 Ict carbs installed?, Opinions |
surfdogskier |
Oct 15 2019, 09:08 AM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
Looking for those out there that have Weber 34 ICT carbs on their ride, particularly on a 1.7. What do you think of them? Are you happy with them? Do you wish you upgraded to 40's?
porschetub |
Oct 15 2019, 01:48 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
These carbs were a great remedy when they came out for the bus owner that had worn out Solex's ,properly fitted and jetted they were a good set up and certainly an improvement over the centre mount Weber.
They come with small venturies so offer good power low down but couldn't be described as a performance carb,the set I had on a single port T1 motor were easy to dial in and balance and stayed that way,some say the later type with the power valves went some way to cure the flat spot when used with a 009. These are an old design and were commonly fitted to some British Ford models back in the 60's and 70's,originally made by Weber then made under license in Spain. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:59 PM |
