GB CLOSES in a few hours 31st for late window scrapers with new fuzzey (non-sucking), Basically buy the aluminum strips at a discount seals are FREE or just buy the seals on GB |
mb911 |
Oct 16 2019, 10:11 AM
914 Guru Group: Members Posts: 6,796 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
in for a set with aluminum tracks
drem914 |
Oct 16 2019, 10:43 AM
Senior Member Group: Members Posts: 1,025 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
Mark, I am in for a set, but is the bulb that slides into the aluminum track larger than the last ones you did? My issue with the scrappers was the bulb portion kept popping out of the track. I went and installed earlier model scrappers and it went into the track with the right tension and does not pop out every time I roll up the windows. is there a difference in the aluminum door track between early model and late model?
Oct 16 2019, 10:53 AM
Resident German Group: Admin Posts: 41,601 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Me me me me me me ...
(IMG:style_emoticons/default/biggrin.gif) |
mbseto |
Oct 16 2019, 11:06 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Also interested in the early/late model question...
Literati914 |
Oct 16 2019, 12:08 PM
Senior Member Group: Members Posts: 1,427 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
IronHillRestorations |
Oct 16 2019, 12:22 PM
I. I. R. C. Group: Members Posts: 6,712 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I truly appreciate all you go through to bring good parts Mark.
That said, the lubricity (not sure if that's the right term) and durometer of the squeegees of yours that I saw was not right. They looked the part but the rubber was so sticky it pulled out of the channel. My thinking was that a harder rubber wouldn't stick to the glass and pull out. |
Mikey914 |
Oct 16 2019, 01:40 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Our rubber for these is the same durometer used on 90% of the other seals. The thinner seals seem more soft but are not. They do harden over time, so one of the fixes was to bake them. Any harder they become more difficult to install. A catch 22, unless you change another variable, which we just did.
Mike D. |
Oct 16 2019, 06:39 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
Oh, But of course!
Thanks! |
drem914 |
Oct 16 2019, 08:13 PM
Our rubber for these is the same durometer used on 90% of the other seals. The thinner seals seem more soft but are not. They do harden over time, so one of the fixes was to bake them. Any harder they become more difficult to install. A catch 22, unless you change another variable, which we just did. Any chance you can shed some light on the bulb size between early and late models? BTW thanks for sending the door card nut arm rest nut plates. |
burton73 |
Oct 16 2019, 08:31 PM
burton73 Group: Members Posts: 3,484 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Mikey914 |
Oct 16 2019, 09:27 PM
The early "correct" version was made specifically for the 914 you can see the profile is completely different. The early do not grab the window. At some point in 73 they decided to superseded the part with the 911 one they already made as it "worked"
You can see where I have installed it on my 75 (the early) it's actually completely different. Only the bulb size is the same. That's the early / late deal. |
djway |
Oct 16 2019, 10:32 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Im in
VaccaRabite |
Oct 17 2019, 07:24 AM
En Garde! Group: Admin Posts: 13,417 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
In for a set.
Zach |
914Sixer |
Oct 17 2019, 10:57 AM
914 Guru Group: Members Posts: 8,862 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Down for one.
drem914 |
Oct 17 2019, 04:19 PM
I'm still in for a set, I'll have to see how the bulb size works out. because there is definite difference between the two stiles and it may be I got the early style from the pelican which could account for the possible manufacturing difference in size/tolerance.
Thanks, |
broomhandle |
Oct 17 2019, 05:08 PM
Member Group: Members Posts: 290 Joined: 26-June 09 From: Half Moon Bay, CA Member No.: 10,512 Region Association: Northern California |
I am in for a set. (IMG:style_emoticons/default/smile.gif)
theer |
Oct 18 2019, 08:00 AM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
yes, please.
gjames |
Oct 18 2019, 09:05 AM
Newbie Group: Members Posts: 10 Joined: 3-March 13 From: Virginia Member No.: 15,606 Region Association: None |
I am in for set.
George |
FlacaProductions |
Oct 18 2019, 11:11 AM
Senior Member Group: Members Posts: 1,550 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I have a set of yours (the one that "suck" - ha!) ready to go in, @Mikey914 but I should probably get these instead and avoid the hassle/frustration, right?
(you crack me up with the title of this thread....) |
Mikey914 |
Oct 18 2019, 12:28 PM
I have a set of yours (the one that "suck" - ha!) ready to go in, @Mikey914 but I should probably get these instead and avoid the hassle/frustration, right? (you crack me up with the title of this thread....) Do appreciate your support. If they are unused send back for a refund. No problem. These are a significant improvement. |
Lo-Fi Version | Time is now: 17th April 2024 - 04:20 PM |
