Thinking About Waking Up My Sleeping '74 2.0 |
germaneighter |
Oct 16 2019, 03:18 PM
Member Group: Members Posts: 130 Joined: 9-August 05 From: Tulsa, OK Member No.: 4,563 |
It's not been on the road for 6-7 years except for a week back in early 2016 while doing a clutch replacement on my Boxster. It wasn't running great during that week but it got me to work and back. I suspected the injectors were gunked-up.
I've been saving this car for retirement - restoration project but I'm still a few years out and my energy level coupled with joint pain got me thinking maybe I should just get it running and enjoy driving it while I still can. My basic plan is: Drain fuel system clean injectors replace fuel & vacuum lines New plugs and wires adjust valves new battery The ignition is a crane unit - can't remember the specifics. Tires were near new when I first stopped driving it but probably flat spots now. Any additional suggestions to get it back on the road? |
Mikey914 |
Oct 16 2019, 07:29 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Drain the fuel
add a few new gallons New battery - or charge disconnect the ignition coil wire and crank over for about a minute I'd bet it fires right up once you connect the coil back up check the brakes and drive it down to get the new plugs and wires and what you need. |
Lo-Fi Version | Time is now: 21st May 2024 - 02:30 PM |
