Thinking About Waking Up My Sleeping '74 2.0 |
germaneighter |
Oct 16 2019, 03:18 PM
Member Group: Members Posts: 130 Joined: 9-August 05 From: Tulsa, OK Member No.: 4,563 |
It's not been on the road for 6-7 years except for a week back in early 2016 while doing a clutch replacement on my Boxster. It wasn't running great during that week but it got me to work and back. I suspected the injectors were gunked-up.
I've been saving this car for retirement - restoration project but I'm still a few years out and my energy level coupled with joint pain got me thinking maybe I should just get it running and enjoy driving it while I still can. My basic plan is: Drain fuel system clean injectors replace fuel & vacuum lines New plugs and wires adjust valves new battery The ignition is a crane unit - can't remember the specifics. Tires were near new when I first stopped driving it but probably flat spots now. Any additional suggestions to get it back on the road? |
dr914@autoatlanta.com |
Oct 17 2019, 09:00 AM
914 Guru Group: Members Posts: 7,868 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I would put some marvel mystery oil in the cylinders overnight then turn the car over the next day (with the spark plugs out) then remove the fuel pump relay and air cleaner, make sure the car has a spark and try to fire it up on some spray gas (fire extinguisher on hand!!!!!!!!) keep spraying the gas until the engine runs smoothly. THEN change the oil, clean the strainer basket, drain the gas, look in the tank for cleanliness, put a new fuel filter on and make sure that the fuel pump cycles (if not and it has the initial electric pulse, tap it with a light hammer) then check the fuel pressure and try to fire it up before you take the car apart and do too many things to complicate the process. After you get the car running then try to drive it before doing anything else (assuming the transmission is full) and see what else needs to be done besides a THOROUGH service
It's not been on the road for 6-7 years except for a week back in early 2016 while doing a clutch replacement on my Boxster. It wasn't running great during that week but it got me to work and back. I suspected the injectors were gunked-up. I've been saving this car for retirement - restoration project but I'm still a few years out and my energy level coupled with joint pain got me thinking maybe I should just get it running and enjoy driving it while I still can. My basic plan is: Drain fuel system clean injectors replace fuel & vacuum lines New plugs and wires adjust valves new battery The ignition is a crane unit - can't remember the specifics. Tires were near new when I first stopped driving it but probably flat spots now. Any additional suggestions to get it back on the road? |
ctc911ctc |
Oct 17 2019, 12:17 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
I would put some marvel mystery oil in the cylinders overnight then turn the car over the next day (with the spark plugs out) then remove the fuel pump relay and air cleaner, make sure the car has a spark and try to fire it up on some spray gas (fire extinguisher on hand!!!!!!!!) keep spraying the gas until the engine runs smoothly. THEN change the oil, clean the strainer basket, drain the gas, look in the tank for cleanliness, put a new fuel filter on and make sure that the fuel pump cycles (if not and it has the initial electric pulse, tap it with a light hammer) then check the fuel pressure and try to fire it up before you take the car apart and do too many things to complicate the process. After you get the car running then try to drive it before doing anything else (assuming the transmission is full) and see what else needs to be done besides a THOROUGH service It's not been on the road for 6-7 years except for a week back in early 2016 while doing a clutch replacement on my Boxster. It wasn't running great during that week but it got me to work and back. I suspected the injectors were gunked-up. I've been saving this car for retirement - restoration project but I'm still a few years out and my energy level coupled with joint pain got me thinking maybe I should just get it running and enjoy driving it while I still can. My basic plan is: Drain fuel system clean injectors replace fuel & vacuum lines New plugs and wires adjust valves new battery The ignition is a crane unit - can't remember the specifics. Tires were near new when I first stopped driving it but probably flat spots now. Any additional suggestions to get it back on the road? (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 06:45 PM |
