345 Pages V « < 175 176 177 178 179 > »
> Rebuiding Inside-out
bkrantz
post Aug 8 2021, 07:12 PM
Post #3521
I finished deck height and other measurements. Taking my time with many repeats, I got deck heights of .036 to 0.38 (and a few times .040). This sounds like a minimum.
Once done measuring, I took off the cylinders and opened the case again, so I can build the engine for real.
djway
post Aug 8 2021, 10:09 PM
Post #3522
I like that red sealant you use. I have been using it to seal up some leaks and it has worked great. (IMG:style_emoticons/default/smile.gif)
bkrantz
post Aug 9 2021, 06:39 PM
Post #3523
Engine build 2 continued.
Here's the cam shaft (Web Cams #86) and bearings, including the second thrust bearing.
bkrantz
post Aug 9 2021, 06:41 PM
Post #3524
Cam bearings and shaft installed in the right half. The blue tape is a reminder to install the cam plug when I put the case halves together.
bkrantz
post Aug 9 2021, 06:42 PM
Post #3525
Getting the left half ready. Here are the cam bearings installed.
bkrantz
post Aug 9 2021, 06:43 PM
Post #3526
And the oil pick-up.
bkrantz
Post #3527
And the baffle plate with edge seals.
bkrantz
post Aug 9 2021, 06:45 PM
Post #3528
I took the opportunity to check the oil pump clearance again.
bkrantz
post Aug 9 2021, 06:46 PM
Post #3529
I got at least .030" between the back of the pump case and the cam gear bolts, without a gasket.
bkrantz
post Aug 11 2021, 06:45 PM
Post #3530
Time to put the case together for the 3rd (4th?) time. And this time I have switched to 574 sealant.
bkrantz
post Aug 11 2021, 06:47 PM
Post #3531
Right case half with a thin smear of sealant, ready for the through-bolts (also with a bit of sealant this time).
bkrantz
post Aug 11 2021, 06:49 PM
Post #3532
All bolted together and torqued up. Now I need my new cylinder heads--more about them later.
bkrantz
post Aug 11 2021, 06:53 PM
Post #3533
Meanwhile, I got started on another project. This is the hidden system, based on a Clarion CMS20.
bkrantz
post Aug 11 2021, 06:55 PM
Post #3534
The main box is pretty light and compact, and provides AM-FM and both USB and Bluetooth streaming, and can be mounted remotely. The control box connects via cable.
bkrantz
post Aug 11 2021, 06:56 PM
Post #3535
My plan so far: mount the remote box inside the center console, behind the gauges.
bkrantz
post Aug 11 2021, 06:58 PM
Post #3536
This should have plenty of clearance.
djway
post Aug 11 2021, 09:20 PM
Post #3537
first song you play must be Mellow Yellow by Donovan (IMG:style_emoticons/default/smile.gif)
bkrantz
post Aug 12 2021, 08:43 PM
Post #3538
To mount the control in the arm rest I had to punch a hole in the bottom big enough for the cable plug.
bkrantz
post Aug 12 2021, 08:45 PM
Post #3539
Another chance to use my industrial Velcro.
bkrantz
post Aug 12 2021, 08:46 PM
Post #3540
Another test fit for the console with hidden head unit.
438 User(s) are reading this topic (438 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 5th October 2026 - 08:41 PM
