345 Pages V « < 180 181 182 183 184 > »
> Rebuiding Inside-out
bkrantz
post Aug 31 2021, 08:39 PM
Post #3621
QUOTE(930cabman @ Aug 30 2021, 07:16 AM) *
QUOTE(bkrantz @ Aug 29 2021, 08:16 PM) *
Now I have one very small plug left over. I don't see any of the small galleys that were opened and threaded.
Probably 1/8" NPT, would be installed on the face of the case near the dip stick tube. Take your time, don't get too anxious and miss a step or two.
Thanks for posting, many of us are following your build
Thanks--as soon as I get back to my garage I will check that.
930cabman
post Sep 3 2021, 05:50 AM
Post #3622
Bob,
have a look at post # 3605, it would be directly to the left of the fan hub. The factory plug appears to still be in place.
bkrantz
post Sep 3 2021, 07:36 PM
Post #3623
QUOTE(930cabman @ Sep 3 2021, 05:50 AM) *
Bob,
Yes. As far as I can tell, all the very small plugs are still in place (and look solid).
raynekat
post Sep 3 2021, 08:51 PM
Post #3624
Bob....did anyone ever tell you that you act like an engineer?
Ha! I almost forgot, you are an engineer.
Love watching you get into the minutia of it all.
Well done man.
bkrantz
post Sep 4 2021, 07:35 PM
Post #3625
QUOTE(raynekat @ Sep 3 2021, 08:51 PM) *
Well done man.
To be fair to all actual engineers, I am only a scientist by training. But maybe an aspiring engineer by compulsion.
bkrantz
post Sep 4 2021, 07:37 PM
Post #3626
Speaking of which, I tried again to make my new oil dipstick tube.
Here are two hardened steel rods (from McMaster-Carr): 7.4 and 7.5 mm.
bkrantz
post Sep 4 2021, 07:40 PM
Post #3627
Got my bench grinder onto my bench. Some day in my dream shop I will have more bench space.
bkrantz
post Sep 4 2021, 07:42 PM
Post #3628
I ground the end of the 7.4 mm rod, so I can use it as a mandrel for the 8.0 mm tubing.
bkrantz
post Sep 4 2021, 07:44 PM
Post #3629
I first tried to force the rod into the tubing cold, but that did not work.
So I used a propane torch to heat the rod and tubing.
bkrantz
post Sep 4 2021, 07:45 PM
Post #3630
That worked, especially after I refined my technique to heat the tubing a small section at a time.
bkrantz
post Sep 4 2021, 07:47 PM
Post #3631
But the end result was too much enlargement. I need the end of the dipstick tube to have an OD of about 7.35 mm, but got 7.45.
So back online to order a smaller diameter rod.
bkrantz
post Sep 5 2021, 08:53 PM
Post #3632
Still waiting for several parts to arrive, so I can fool with some miscellaneous stuff, like the hidden antenna that will connect to my hidden audio system. I have no idea how well this will work, but I will find out eventually.
bkrantz
post Sep 5 2021, 08:54 PM
Post #3633
Here is my current plan: mounting the antenna pad inside the upper corner of the windshield.
bkrantz
Post #3634
The wire goes along the A-pillar.
bkrantz
post Sep 5 2021, 08:55 PM
Post #3635
And through the gap at the side of the dashboard.
bkrantz
post Sep 5 2021, 08:57 PM
Post #3636
I re-installed the A-pllar pad, the left the antenna ready to mount to the windshield. (Reminder: I need to get on sourcing the windshield.)
bkrantz
post Sep 5 2021, 08:58 PM
Post #3637
At the bottom end, I connected the antenna lead. And then the harness for the center console gauges.
bkrantz
post Sep 5 2021, 09:03 PM
Post #3638
And then I worked on the replacement console panel. I took the custom cover that had been mounted on the original (cracked) panel. Staples in the MDF did not work well, so I decided to use spray adhesive.
bkrantz
post Sep 5 2021, 09:04 PM
Post #3639
Not my neatest effort, but I got the vinyl glued on evenly, and the underside edges eventually stuck in the right place.
bkrantz
post Sep 5 2021, 09:06 PM
Post #3640
Once everything dries, I will clean up the mess with 3M adhesive remover.
489 User(s) are reading this topic (489 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 5th October 2026 - 10:19 PM
