| bkrantz |
Sep 13 2021, 07:14 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,800 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Sender installed.
Attached thumbnail(s) |
| bkrantz |
Sep 13 2021, 07:15 PM
Cover with grommet (not yet poked for a hole) and seal rings.
| bkrantz |
Sep 13 2021, 07:16 PM
Cover installed temporarily. I will make a new lead and attach that , but only after I get done with most of the engine build.
| bkrantz |
Sep 13 2021, 07:17 PM
I also found a spare 8 mm copper washer.
| bkrantz |
Sep 13 2021, 07:19 PM
That seals up the distributor bracket hole. Not needed since I will eventually run an electronic ignition. The kit includes a plug for the dizzy hole.
| bkrantz |
Sep 13 2021, 07:20 PM
One more project today: making an adjustable pushrod for measuring the proper length (once I install the heads and valve train).
| bkrantz |
Sep 13 2021, 07:21 PM
As many people have done before, it was easy to run a M6 tap into the cut ends.
| bkrantz |
Sep 13 2021, 07:22 PM
Ready to use.
| bkrantz |
Sep 14 2021, 07:37 PM
Back to work on the frunk floor panel. Here it is sanded.
| bkrantz |
Sep 14 2021, 07:38 PM
And painted.
| bkrantz |
Sep 14 2021, 07:39 PM
Once I get Perlon material, I will cover the top side.
| bkrantz |
Sep 15 2021, 07:15 PM
Big day: installing the first part of the Dubshop Megasquirt EFI and ignition.
This is the crank sensor kit, with a Hall sensor and trigger wheel. Attached thumbnail(s) |
| bkrantz |
Sep 15 2021, 07:18 PM
First attempt to fit the toothed wheel, and the center hole is too small, by about 0.1 mm.
| bkrantz |
Some light filing and smoothing, and...
| bkrantz |
Sep 15 2021, 07:21 PM
It now slides onto the hub, but it rocks a bit and does not sit flat. I confirmed this with a machined straight edge.
| bkrantz |
Sep 15 2021, 07:23 PM
After some rounds of light hammering and checking, I got the wheel to mount flat.
| bkrantz |
Sep 15 2021, 07:24 PM
Next, I mounted the sensor to the supplied bracket--cool Dubshop logo cut-out.
| bkrantz |
Sep 15 2021, 07:26 PM
The bracket mounts using two of the case edge bolts. It can slide about 10mm forward and back. The sensor can also adjust closer to the crank axis.
| bkrantz |
Sep 15 2021, 07:29 PM
The desired clearance is less than 3 mm, and I aimed for just less than 2 mm.
| bkrantz |
I got about 1.8 mm.
Lo-Fi Version | Time is now: 5th October 2026 - 11:53 PM |
