345 Pages V « < 184 185 186 187 188 > »
> Rebuiding Inside-out
bkrantz
post Sep 15 2021, 07:36 PM
Post #3701
With the wheel temporarily bolted to the fan hub, its all ready for initial testing.
bkrantz
post Sep 16 2021, 07:48 PM
Post #3702
Here's the setup for testing the signal, with 12 V to the sensor, and then a voltmeter across the sensor output lead.
bkrantz
post Sep 16 2021, 07:50 PM
Post #3703
Tooth over the sensor, should be under 0.25 V.
bkrantz
Post #3704
Check.
bkrantz
post Sep 16 2021, 07:51 PM
Post #3705
Gap over the sensor, should be 12 V.
bkrantz
post Sep 16 2021, 07:52 PM
Post #3706
Check (the battery is a bit low).
And I cycled the entire wheel, and got consistent output.
bkrantz
post Sep 16 2021, 07:53 PM
Post #3707
Let night, UPS brought my new Hoffman heads, by way of LN Engineering.
bkrantz
post Sep 16 2021, 07:54 PM
Post #3708
Very sexy, right?
bkrantz
post Sep 16 2021, 07:56 PM
Post #3709
I was going to wait until Saturday, but could not resist. I checked all the fits, and rechecked the deck height, and then started putting the P&C on for real. That includes piston pin retaining clips. First one on the bench is easy.
bkrantz
post Sep 16 2021, 07:57 PM
Post #3710
Second one is a bit harder.
bkrantz
post Sep 16 2021, 07:59 PM
Post #3711
For mounting the cylinders, I used a thin smear of 5900 at the base.
bkrantz
post Sep 16 2021, 08:00 PM
Post #3712
Left head mounted and torqued.
bkrantz
post Sep 16 2021, 08:01 PM
Post #3713
More engine!
DRPHIL914
post Sep 17 2021, 06:47 AM
Post #3714
Dr. Phil
(IMG:style_emoticons/default/piratenanner.gif) looking good! are you doing 96's with those heads? (are those HAM1 heads)
good stuff for sure, i was on the list to get some on his next batch, but he kind of dropped the ball on me and i had to go a different direction. Just got my motor in the car this weekend, good luck to ya ! what is your break in proceedure for cam and bearning break in?
Phil
bkrantz
post Sep 17 2021, 07:36 PM
Post #3715
RS+ heads, from LN.
Not sure about break in, I am still thinking about assembly!
bkrantz
post Sep 17 2021, 07:43 PM
Post #3716
I got started on the rocker arms today. Here is the kit from Tabari Andrade, who modified my rockers and shaft supports, and supplied new swivel adjusters, shafts, and shims.
bkrantz
post Sep 17 2021, 07:44 PM
Post #3717
That includes several shims in various sizes.
bkrantz
post Sep 17 2021, 07:45 PM
Post #3718
Here is the first mock-up for cylinder #1, following the rule of having a thick shim to the right of each rocker.
bkrantz
post Sep 17 2021, 07:46 PM
Post #3719
First test fit. My goal was to align each rocker just to the right of each valve stem center.
bkrantz
post Sep 17 2021, 07:47 PM
Post #3720
It may not look it, but the hole for the adjuster is offset a bit to the right.
474 User(s) are reading this topic (474 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th October 2026 - 12:30 AM
