| bkrantz |
Sep 17 2021, 07:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,800 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Here is the initial gap. I iterated on filling the gap with shims and maintaining the slight offset of the rocker.
Attached thumbnail(s) |
| bkrantz |
Sep 17 2021, 07:49 PM
Besides the offset rocker alignment, I aimed for .004" freeplay in the entire stack of rockers and shims.
| bkrantz |
Sep 17 2021, 07:51 PM
Left side done.
| bkrantz |
Sep 17 2021, 07:52 PM
And right side.
| bkrantz |
Sep 17 2021, 07:53 PM
At the end, I used all the new shims except one .004", plus I had to scrounge one of my original rocker shaft shims.
| bkrantz |
Sep 18 2021, 07:42 PM
Before going further, I did remember that the sheet metal baffles for under the cylinders need to mount before push rod tubes.
| bkrantz |
Sep 18 2021, 07:43 PM
But I did not remember that the brial cylinders have wider fins, so the baffle edges interfere.
| bkrantz |
Sep 18 2021, 07:46 PM
So, some quick surgery, using shears to cut to rough clearance.
| bkrantz |
Sep 18 2021, 07:49 PM
And then the mini drum sander on my Dremel.
| bkrantz |
Sep 18 2021, 07:50 PM
Getting there.
| bkrantz |
Sep 18 2021, 07:51 PM
Fits!
| bkrantz |
Sep 18 2021, 07:53 PM
Time now for lifters!
| bkrantz |
Cam lube on the end (and assembly lube on the body and bore).
| bkrantz |
Sep 18 2021, 07:54 PM
Then I dropped the lifters in.
| bkrantz |
Sep 18 2021, 07:55 PM
And plugged the holes.
| bkrantz |
Sep 18 2021, 07:58 PM
Now for adjusters, new 10 mm swivel feet. (And old nuts for now.)
| bkrantz |
Sep 18 2021, 07:59 PM
Adjusters installed.
| bkrantz |
Sep 18 2021, 08:02 PM
So then I started to learn about push rod tubes and optimizing length. Here is my adjustable rod in the intake for cylinder #1.
| bkrantz |
Sep 18 2021, 08:06 PM
And my setup for the dial gauge on the valve spring retainer.
| bkrantz |
Sep 18 2021, 08:09 PM
After some quick trials, I measured .427" lift. Spec lift is .423"
Lo-Fi Version | Time is now: 6th October 2026 - 12:30 AM |
