| bkrantz |
Sep 24 2021, 07:53 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,800 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
New knobs!
Attached thumbnail(s) |
| bkrantz |
Sep 24 2021, 07:58 PM
A final trinket: after many months of searching, I found a Porsche crest button for the Nardi wheel that came on the car. I know after-market steering wheels upset some people, but one of the things I changed on my first 914 was the wheel.
| bkrantz |
Sep 24 2021, 07:59 PM
And I like this as the only Porsche crest on the car.
| bkrantz |
Sep 24 2021, 08:01 PM
After that, I fastened down the arm rest, with the hidden control for the hidden audio system, complete with USB plug for phones.
| bkrantz |
Sep 24 2021, 08:02 PM
Here's a shot of the interior, complete except for doors and windshield.
| djway |
Sep 24 2021, 10:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
SWEET
| seanpaulmc |
Sep 25 2021, 05:13 AM
Member ![]() ![]() Group: Members Posts: 464 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States
Here's a shot of the interior, complete except for doors and windshield. Outstanding! (IMG:style_emoticons/default/beerchug.gif) |
| bkrantz |
Sep 25 2021, 07:53 PM
Thanks, guys. I hope all the bits stay together when I try driving.
| bkrantz |
Sep 25 2021, 07:55 PM
More tools! Thats why we play amateur mechanic, right?
I rationalized getting a 12 inch caliper to deal with measuring push rods. And a new dial gauge since my near-antique Sears model was acting odd. Attached thumbnail(s) |
| bkrantz |
Sep 25 2021, 07:56 PM
And while I was shopping, why not a better dial gauge support thing?
| bkrantz |
Sep 25 2021, 07:57 PM
But before playing with new toys, I played with new hardware. I got some M5 Allen head bolts.
| bkrantz |
Sep 25 2021, 07:59 PM
Two of these replace the temporary bolts I used in the centers of the lower sheet metal pieces. This makes my OCD happy, since they match the M6 Allen heads I used for the other spots.
| bkrantz |
Sep 25 2021, 08:01 PM
OK, time to play with the pushrod lengths again. Here is my new dial gauge set up.
| bkrantz |
Sep 25 2021, 08:03 PM
I also made a cardboard template to help with judging alignment. This wedge is 14 degrees, which matches the inclination of the valves relative to the perpendicular of the cylinder head faces.
| bkrantz |
Sep 25 2021, 08:05 PM
Here's a measurement of valve lift on the #1 intake, with a 268 mm push rod length. The lift is .432". I was able to repeat that multiple times.
| bkrantz |
Sep 25 2021, 08:07 PM
And at half-lift, the rocker arm and adjuster nut line up nicely, so the adjuster and valve stem should be in a straight line.
| bkrantz |
Sep 25 2021, 08:09 PM
On the exhaust valve, I got a max lift of .410. As expected, this is less than the intake valve lift, since the rocker arm ratios are a little different. I also got excellent alignment. Again, this was with my adjustable pushrod set to 268 mm.
| bkrantz |
Sep 25 2021, 08:17 PM
For "fun", I installed stock 271 mm pushrods, and .074" shims under the rocker shaft supports. Still on cylinder #1, I got these results:
intake, .432" lift, excellent alignment exhaust, .412" lift, excellent alignment I confirmed these by putting the same shims under the rocker shaft supports for #4, with intake, .432" lift exhaust, .409" lift both with excellent alignment Now I need to decide on my solution: adjustable pushrods or shims. |
| barefoot |
Sep 26 2021, 04:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,556 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Two of these replace the temporary bolts I used in the centers of the lower sheet metal pieces. This makes my OCD happy, since they match the M6 Allen heads I used for the other spots. Yes !!! death the cheese heads, so much easier to deal with using long allen head wrenches (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
| bkrantz |
Sep 26 2021, 07:45 PM
Two of these replace the temporary bolts I used in the centers of the lower sheet metal pieces. This makes my OCD happy, since they match the M6 Allen heads I used for the other spots. Yes !!! death the cheese heads, so much easier to deal with using long allen head wrenches (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) Agreed. Just don't say that in Wisconsin. |
Lo-Fi Version | Time is now: 6th October 2026 - 02:09 AM |
