| bkrantz |
Oct 8 2021, 07:42 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,800 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Test fit, with the new clip taped to the cushion bottom.
Attached thumbnail(s) |
| bkrantz |
Oct 8 2021, 07:45 PM
The test showed the clip in the right location, but it needs a slight angle adjustment.
| bkrantz |
Oct 8 2021, 07:46 PM
To attach the clips, I used some sheet metal screws. Just in case the cushion collapses to zero, I blunted the screw tips.
| bkrantz |
New clip in place.
| bkrantz |
Oct 8 2021, 07:47 PM
And...it works. The front of the cushion will not lift up.
| bkrantz |
Oct 8 2021, 07:48 PM
And I made the same thing for the passenger side.
| bkrantz |
Oct 9 2021, 07:47 PM
I got some new 5/16 (8 mm) drill bits. I found Milwaukee cobalt bits at Home Depot, labeled for hard metal, including stainless steel. I also slowed down the drill RPM and used cutting oil. Much better drilling success.
| bkrantz |
Oct 9 2021, 07:48 PM
Holes drilled in 8 shims with the proper offset.
| bkrantz |
Oct 9 2021, 07:50 PM
And then de-burred. Ready to get back to engine assembly.
| bkrantz |
Oct 9 2021, 07:51 PM
Shims in place, under the rocker shaft towers.
| bkrantz |
Oct 9 2021, 07:52 PM
Ready for new pushrod tubes and seals.
| bkrantz |
Oct 9 2021, 07:56 PM
Lots of oil on the seals before rolling them onto the tubes, and then I pushed the tubes into place.
| bkrantz |
Oct 9 2021, 07:57 PM
I even remembered the pushrod retaining wires.
| bkrantz |
Oct 9 2021, 08:02 PM
After lubing the rockers, shafts, spacers, pushrods, and adjusters, I put everything together and torqued the new high-strength retaining nuts. And then I gave the adjusters a quick clearance setting. One side done!
| bkrantz |
Oct 10 2021, 08:10 PM
I just got started on the other side today, when the weather outside proved too tempting.
| bkrantz |
Oct 10 2021, 08:13 PM
We took a 3 hour hike in the San Juan Mountains, and the aspen colors were stunning.
| nivekdodge |
Oct 10 2021, 09:35 PM
Member ![]() ![]() Group: Members Posts: 341 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region
| Puebloswatcop |
Oct 11 2021, 07:57 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,762 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
| bkrantz |
Oct 11 2021, 07:20 PM
Here's the re-plated latch installed. Those pieces look fantastic, may I ask the process? Easy process! Just clean the old parts and send to FPS (www.fpswi.com), and specify what finish you want. They are quick and cost-effective. |
| bkrantz |
Oct 11 2021, 07:23 PM
Left side valve gear in place and quickly adjusted.
Lo-Fi Version | Time is now: 6th October 2026 - 03:51 AM |
