344 Pages V « < 199 200 201 202 203 > »
> Rebuiding Inside-out
bkrantz
post Oct 27 2021, 07:33 PM
Post #4001
Right side sheet metal.
bkrantz
post Oct 27 2021, 07:34 PM
Post #4002
Instead of the stock cheese head screws, I got the bag of Allen head bolts from 914 Rubber.
bkrantz
post Oct 27 2021, 07:36 PM
Post #4003
It took a bit of twisting and shoving, but I got the right side installed. Maybe the sheet metal warped a bit when the powder coating shop sand-blasted it.
bkrantz
post Oct 27 2021, 07:37 PM
Post #4004
Left side sheet metal.
bkrantz
post Oct 27 2021, 07:38 PM
Post #4005
This side went on easier.
autopro
post Oct 28 2021, 09:18 AM
Post #4006
Looks great, especially with all that nice new hardware.
bkrantz
post Oct 28 2021, 08:07 PM
Post #4007
More sheet metal today. Here's the rear piece.
bkrantz
post Oct 28 2021, 08:08 PM
Post #4008
Sheet metal is almost complete--or is it?
bkrantz
post Oct 28 2021, 08:10 PM
Post #4009
I tried to fit the manifolds--should have done this earlier.
bkrantz
post Oct 28 2021, 08:13 PM
Post #4010
The right side was OK, but the left side sheet metal interferes with the manifold flange.
bkrantz
post Oct 28 2021, 08:14 PM
Post #4011
That led to several attempts to file the opening, test fit, and then finally paint the raw edges.
bkrantz
post Oct 28 2021, 08:15 PM
Post #4012
I also filed down the washers.
bkrantz
post Oct 28 2021, 08:16 PM
Post #4013
In the end, everything fits on both sides.
bkrantz
post Oct 28 2021, 08:17 PM
Post #4014
Now all these pieces are on for real. I hope.
bkrantz
post Oct 28 2021, 08:20 PM
Post #4015
I also got my second replacement for the alternator vent rubber elbow. My old original is on the left, 914 Rubber repro in the middle, and new (repro) on the right. Note the new one shipped with a cheesy worm drive clamp.
bkrantz
post Oct 28 2021, 08:22 PM
Post #4016
I transferred the original clamp to the new elbow.
bkrantz
post Oct 28 2021, 08:23 PM
Post #4017
Installed into the rear of the blower housing.
bkrantz
post Oct 28 2021, 08:26 PM
Post #4018
And retaining clip in place.
Puebloswatcop
post Oct 29 2021, 07:08 AM
Post #4019
I admire your attention to detail. You've gotta be seeing the light at the end of the tunnel and this time its not a train coming the other direction. Great work Bob
bkrantz
post Oct 29 2021, 07:26 PM
Post #4020
QUOTE(Puebloswatcop @ Oct 29 2021, 07:08 AM) *
Thanks. To get to the light, I figure I have these remaining jobs:
Mock up the EFI and ignition on the engine while on the stand
Also mock up EFI component on the body, and lay out wiring
Install clutch
Mate engine and trans, install in car
Install EFI and ignition, complete all plumbing and wiring
Build up half shafts and install
Install heat exchangers, muffler, and all ducts
Set up initial EFI/ignition program and test star
Tune program
Bleed and adjust brakes
Mount new tires
DIY wheel alignment
Install door hardware, glass, and trim
Go for a drive?
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 17th November 2025 - 01:40 PM
