344 Pages V « < 204 205 206 207 208 > »
> Rebuiding Inside-out
bkrantz
post Nov 8 2021, 07:53 PM
Post #4101
New fuzzy channel for the window guide.
bkrantz
post Nov 8 2021, 07:54 PM
Post #4102
Installed.
bkrantz
post Nov 8 2021, 07:56 PM
Post #4103
Now the fun part: trying to get the seal seated in the door.
bkrantz
post Nov 8 2021, 07:57 PM
Post #4104
After lots of struggle, I could not get the front end to seat properly.
bkrantz
post Nov 8 2021, 07:59 PM
Post #4105
And the outer part of the seal will not seat horizontal, with a bulge next to the retainer tab.
bkrantz
post Nov 8 2021, 08:01 PM
Post #4106
And worst of all, I split the outer seal above the slit I made for the tab.
I know others have done this by cutting the tab off the retainer, but I figure Porsche put that there for a reason. I will have to consider options.
iankarr
post Nov 8 2021, 08:32 PM
Post #4107
Definitely tricky business. Mark at 914rubber provided the best tip...wrap the triangle glass and channel with cellophane pack-wrap. It keeps everything together and stable while you muscle things in. I also needed to to trim things a bit to get everythng to seat properly. You may want to check that the glass isn't hitting the frame, keeping the seal from being far enough forward for it to fit in the channel.
bkrantz
post Nov 9 2021, 08:04 PM
Post #4108
Thanks, Ian. I tried a few times with different approaches, but will never get the bottom edge to sit evenly because of the tab on the retaining bracket. I have ordered the factory part, which should have a groove for the tab.
raynekat
post Nov 10 2021, 03:06 AM
Post #4109
Bob....I must have tried installing this triangle window 20 times. Couldn't get the 914Rubber seal to work.
Eventually went back to the factory seal and finally had a satisfactory result.
Getting the door seals to work correctly on the A, B pillars and targa top is definitely a challenge.
Takes a lot of patience and cyphering. (IMG:style_emoticons/default/wink.gif)
Hopefully you won't have fitment issues when you go about mounting the door on the car.
I had my doors installed, such that I could check fitment against the A pillar.
There is definitely a lot of tweaking that took place in my case.
bkrantz
post Nov 10 2021, 09:01 PM
Post #4110
You are right, Doug. If there is any general category of jobs, anything that involves rubber seems to be most challenging. And especially where multiple parts have to align properly. Best to do those on positive karma days. And as you will see, I have decided to try the doors-on method.
bkrantz
post Nov 10 2021, 09:05 PM
Post #4111
Yup, doors (at least right door), going on the car. How about some new door stop retaining pins? The ones from 914Rubber measure .01 inch larger diameter than stock. To make them fit, I had to drill the stay arm, and ream out the paint from the holes in the tabs on the door jamb.
bkrantz
Post #4112
Tidy fit with no slop.
bkrantz
post Nov 10 2021, 09:07 PM
Post #4113
Quick adjustment of hinge positions and latch looks pretty good. Once I get the new vent window seals I can try that again.
bkrantz
post Nov 10 2021, 09:12 PM
Post #4114
Meanwhile, back to the engine. Here is the new (used) alternator front seal, plus some more hardware.
bkrantz
post Nov 10 2021, 09:14 PM
Post #4115
The hardware furthers my quest to replace all the slotted fasteners on the engine with Allen heads. Note the big Philliips screws are not original but I used them when I first put the blower housing together.
bkrantz
post Nov 10 2021, 09:16 PM
Post #4116
I pulled all the sheet metal off the front, just so you can see the housing with Allen fasteners.
bkrantz
post Nov 10 2021, 09:17 PM
Post #4117
Alternator ring in place.
bkrantz
post Nov 10 2021, 09:18 PM
Post #4118
With all the sheet metal back in place, it was time for a new V-belt.
bkrantz
post Nov 10 2021, 09:20 PM
Post #4119
Just a bit of tension, and ready.
TX914
post Nov 11 2021, 06:19 AM
Post #4120
Alan-B
QUOTE(bkrantz @ Nov 10 2021, 10:14 PM) *
Funny story - Many years ago I replaced every slotted fastener on the sheet metal with Allen heads because I thought they were easier to work with and looked cool. The next time I had the car in the shop the mechanic replaced every one of them with the original slotted fasteners without even asking. I guess he did not agree with that mod. (IMG:style_emoticons/default/smile.gif) I think they were not tapered and were thus harder to thread.
- Lo-Fi Version Time is now: 17th November 2025 - 07:28 AM
