Another small idle problem - any help? |
StarBear |
Oct 17 2019, 05:14 PM
Senior Member Group: Members Posts: 1,885 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Lots of idle problem threads in the Garage, but I think this is a new one not previously covered:
1. 1974 1.8 L-Jet; regular points/condenser and dual port vaccuum cannister. 2. Runs flawlessly and reliably; idles about 1000 rpm at startup 3. Just recently, when at a stop, the idle drops back to only 1200 rpm instead of 1000. 4. If I engage the clutch just a tad the idle goes back down to 1000 and stays there (until the next stop). (IMG:style_emoticons/default/wacko.gif) I've checked the throttle spring and such. Maybe something with the vaccuum canister or some other little demon hiding somewhere? In advance, thanks for your knowledge and insights! |
jcd914 |
Oct 17 2019, 07:06 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I would check that the mechanical advance mechanism in the distributor moves freely.
And lube it while you are checking it. It takes a drop or two of light oil on the felt pad in the distributor shaft under the rotor. It is an often missed maintenance item and the the advance sticks. Jim |
Mikey914 |
Oct 17 2019, 07:14 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
2nd that
rjames |
Oct 17 2019, 09:21 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
My 2.0 just started doing this. I think I’ve traced it to a bad decel valve that isn’t completely closing since disconnecting seems to correct the issue and allow the idle to drop to 800-900 rpms.
Olympic 914 |
Oct 18 2019, 06:56 AM
Group: Members Posts: 1,670 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
have to check that... My idle is always 1100- 1200. just thought it was the nature of the beast. I've gotten used to it. |
StarBear |
Oct 18 2019, 02:17 PM
I would check that the mechanical advance mechanism in the distributor moves freely. And lube it while you are checking it. It takes a drop or two of light oil on the felt pad in the distributor shaft under the rotor. It is an often missed maintenance item and the the advance sticks. Jim Will try it tomorrow and let you know. Thanks!! |
StarBear |
Oct 18 2019, 02:19 PM
My 2.0 just started doing this. I think I’ve traced it to a bad decel valve that isn’t completely closing since disconnecting seems to correct the issue and allow the idle to drop to 800-900 rpms. Hmmm; thought about that but other posts seem think the valve works only on startup or something. Do you knowof any way to check or clean it (just to be sure)? I appreciate your response and help. |
StarBear |
Oct 18 2019, 02:22 PM
(IMG:style_emoticons/default/idea.gif) have to check that... My idle is always 1100- 1200. just thought it was the nature of the beast. I've gotten used to it. It's my OCD.... (IMG:style_emoticons/default/beer.gif) And Virgo and (retired) engineer. I'm in long-term recovery... (IMG:style_emoticons/default/confused24.gif) |
rjames |
Oct 18 2019, 03:43 PM
My 2.0 just started doing this. I think I’ve traced it to a bad decel valve that isn’t completely closing since disconnecting seems to correct the issue and allow the idle to drop to 800-900 rpms. Hmmm; thought about that but other posts seem think the valve works only on startup or something. Do you knowof any way to check or clean it (just to be sure)? I appreciate your response and help. Easy: Just block off / plug the connections to/from it (take it out of the loop). |
StarBear |
Oct 19 2019, 01:49 PM
I would check that the mechanical advance mechanism in the distributor moves freely. And lube it while you are checking it. It takes a drop or two of light oil on the felt pad in the distributor shaft under the rotor. It is an often missed maintenance item and the the advance sticks. Jim Yep, that did the trick! Took a few miles and engine warmup on a great fall afternoon. Again running like a champ! Thanks ever so much, Jim. I love 914world (and the people in it...) (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 03:01 AM |
