tested my battery what do you think?, 1974 914 1.8 |
brcacti |
Oct 19 2019, 11:13 AM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, I got out my battery tester my dad left me, (he was a car guy), I am a botanist and natural healer, never looked at it, used it but today I tested my 914 battery and it read less than 12 volts, about 11.8 or 11.9. Car would not start. I put it on 20 cca and it read 400 out of 520 I had it set for. On battery test it was in the red replace, not real far down but significant. The date on the battery said 10/13, I guess it is 6 years old. I will bring it to wal mart and have them test it also and buy a new one, do you all agree it is bad with those test results?
brcacti |
Oct 19 2019, 11:14 AM
I meant 520 cca
Rand |
Oct 19 2019, 11:20 AM
"Would not start" doesn't help. Did it crank? Before I'd throw money at a new battery I would at least jump start it and test voltage while running.
Tdskip |
Oct 19 2019, 11:23 AM
Advanced Member Group: Members Posts: 3,678 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
That is low, should be 12+ but may just need a charge. Autozone etc (or Walmart) can test and tell you if it is salavageable.
Don’t be shocked (drum roll please) if you need a new one. I’d expect it would turn the car over as-is however... |
brcacti |
Oct 19 2019, 11:34 AM
Did not crank was fine a couple of days ago. Appears to be 6 years old, the age and reading less than 12 volts even when connected to battery posts, not connectors plus it was in the red replace zone. I am FAR from an expert but would bet it is bad.
Oct 19 2019, 11:57 AM
914-6 GT in waiting Group: Members Posts: 19,221 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The battery in my wife’s 2016 Honda died when we tried to restart her car after driving 500 miles to Maine and stopping twice. Testing at advance auto showed it was bad. 3 years. (IMG:style_emoticons/default/dry.gif)
I do keep my Porsche batteries on a battery tender jr. it’s recommended for the optima batteries. |
dr914@autoatlanta.com |
Oct 19 2019, 12:07 PM
914 Guru Group: Members Posts: 7,810 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
check the fluid level, top with distilled water and charge it first
brcacti |
Oct 19 2019, 12:11 PM
What is a battery tender jr.? I did check the fluid levels and charged it many hours last night and a little this morning before trying to crank
brcacti |
Oct 19 2019, 12:12 PM
Oct 19 2019, 12:34 PM
What is a battery tender jr.? I did check the fluid levels and charged it many hours last night and a little this morning before trying to crank They are sold at most flaps and they line for $25-30 It’s a smart trickle charger. It has a chip to monitor the charge. |
RAX914 |
Oct 19 2019, 12:37 PM
Member Group: Members Posts: 99 Joined: 20-August 14 From: California Member No.: 17,801 Region Association: None |
brcacti |
Oct 19 2019, 01:02 PM
THANKS to all who replied with information, I think a 6 year old battery is very old is that right? I am a novice but I think it lasted so long because it was stored some of the time?
Spoke |
Oct 19 2019, 02:21 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
StarBear |
Oct 19 2019, 03:12 PM
Senior Member Group: Members Posts: 1,845 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Appears to be 6 years old, Way beyond it's service life. Get a new battery. Batteries can dump in a moment. Good today..Won't start 10 minutes later. Oh, and experience -- since most (?) originally had the clock wired directly to the battery, sitting that long running the clock would drain the battery, too. Added a battery disconnect for when not in use, and a disconnect switch to the radio, too (left it on once..); doubles as a fake kill switch to add to any potential thief's confusion. |
fiacra |
Oct 19 2019, 03:22 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 302 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Appears to be 6 years old, Way beyond it's service life. Get a new battery. Batteries can dump in a moment. Good today..Won't start 10 minutes later. (IMG:style_emoticons/default/agree.gif) Given what you describe, and the voltage you are getting when you test it, this is a dead battery. As almost all of us can attest, the choice of batteries is important. Lots of opinions on what to buy, but I don't think anybody would argue with a sealed battery. You can find good discussions about this, but here is one thread http://www.914world.com/bbs2/index.php?act...=2&t=323517 |
Rand |
Oct 19 2019, 03:24 PM
Just me, I'd try swapping batteries... take one from another car. See if the problem persists. I guess a new battery would be an ok investment, but I try to never spend money on parts that I'm not certain are bad.
porschetub |
Oct 19 2019, 04:21 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
As mentioned don't muck around,most batteries don't last that long anyway,good luck.
Lo-Fi Version | Time is now: 19th April 2024 - 01:00 PM |
