Reverse Lights |
Reverse Lights |
ballsyfacts914 |
Oct 19 2019, 02:05 PM
Member Group: Members Posts: 82 Joined: 28-August 19 From: East Bay Region-SF Bay Area Member No.: 23,413 Region Association: Northern California |
Hi All! Reverse lights don't work, bulbs changed...check. Connections all there...check. Even checked the battery and followed the wires into the engine compartment and don't see any missed connections.
Any suggestions? Thanks |
ballsyfacts914 |
Oct 19 2019, 02:31 PM
Starting to figure it is the pin, what page in Haynes? Or pictures.
Thanks |
Jonathan Livesay |
Oct 19 2019, 02:40 PM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Starting to figure it is the pin, what page in Haynes? Or pictures. Thanks If there is a pin present then it's not that. You can check the switch after verifying that the pin is present by pulling the 2 wires out of the switch and putting an ohm meter across the terminals, if it doesn't drop to zero ohms when you shift into reverse then the switch is bad. |
Lo-Fi Version | Time is now: 28th May 2024 - 10:51 AM |
