Transmission-throw out bearing?, Not sure !! |
sb914 |
Oct 19 2019, 03:14 PM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
So my car makes a grinding noise under load but if I’m just coasting the “ grinding “
Goes away. We pulled the tranny and Noel noticed the throw-out bearing is spinning With ease and “grinding “ check out the video. Does this look right? I really hope this is the problem. I know I could just replace it but I want to be sure beforehand. I planned on putting in a loner tranny until mine was fixed . Hopefully it’s just the TOB ! Video is in post #2 @Dr Evil |
ndfrigi |
Oct 19 2019, 03:18 PM
here are the youtube link of Eddy’s bearing.
https://youtu.be/YCeXWS--O_E https://youtu.be/7zqupPeJMao |
bdstone914 |
Oct 19 2019, 04:34 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
It is dry. Probably worn. I have several at the shop. Ask me tomorrow at the swap meet.
sb914 |
Oct 19 2019, 05:40 PM
It is dry. Probably worn. I have several at the shop. Ask me tomorrow at the swap meet. @bdstone914 Thanks Bruce! Did you hear it in the video? My question is, would this make a “grinding “ noise while driving in gear, but stop while “coasting” in neutral ? It stops grinding when I’m coasting at any speed. |
914Sixer |
Oct 19 2019, 07:54 PM
914 Guru Group: Members Posts: 8,868 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Bearing should be free floating when in gear. Only time it might make noise it when the clutch is engaged.
sb914 |
Oct 19 2019, 08:21 PM
Jonathan Livesay |
Oct 19 2019, 08:25 PM
Senior Member Group: Members Posts: 740 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Bearing should be free floating when in gear. Only time it might make noise it when the clutch is engaged. Are they supposed to spin that freely like in video ? Yes pretty much, it sounds a bit dry but not heavily worn. Grinding under load would seem to me to have more to do with transmission or maybe differential. |
Tbrown4x4 |
Oct 20 2019, 02:23 AM
Senior Member Group: Members Posts: 699 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
My vote is one of the carrier bearings is bad.
Does it make the noise in all the gears under acceleration? Like 914Sixer said, the TO bearing is only loaded when the clutch pedal is depressed. I would put the loaner trans in and tear into the noisy one. And keep Dr Evil's number handy. I can't remember if these have magnetic drain plugs. Drain the oil and look for metal. But surely you drained it before you removed it. (IMG:style_emoticons/default/poke.gif) |
Mark Henry |
Oct 20 2019, 06:01 AM
Bearing should be free floating when in gear. Only time it might make noise it when the clutch is engaged. (IMG:style_emoticons/default/agree.gif) My bug has a release bearing going bad, I only hear it when I press the clutch pedal. But I say that bearing is pretty well done. BTW never rest your foot on the clutch pedal, it will shorten the life of the bearing big time. Also it's important that you have 1/2"-3/4" free play on the pedal so the bearing releases fully. |
sb914 |
Oct 21 2019, 06:05 AM
Bummer (IMG:style_emoticons/default/headbang.gif) I was hoping it was the TOB. I guess I’ll get a new TOB install it the the loner trans ( thanks Noel ) and see what happens from there. Thanks guys
Tbrown4x4 |
Oct 21 2019, 06:41 AM
Keep us posted. I'm dying to know where that noise is coming from.
Dr Evil |
Oct 24 2019, 02:01 PM
Send me your transmission! Group: Members Posts: 22,993 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Oooo, that dry.
For piece of mind, drain the tranz, look for metal, and pull the side cover. 19mm socket on a impact driver is easy as it is only like 9ft/lb (supposed to be), then 13mm nuts, then soft hammer and tap the side cover off. Once that is done, you can see the one diff bearing, and more importantly, the ring, pinion, one side of the input and pinion bearings, to see if that is the issue. If you really wanna go balls out, pull the stack and inspect thoroughly. A seal kit is all that should cost you if no issue and then you can KNOW how things are. I worry that your pinion bearing in the plate is toast, though, so may wish to pull tail cone anyway and have a look for metal. Cant really see it without pulling 1st. Need a DVD? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/happy11.gif) |
ndfrigi |
Oct 30 2019, 03:10 PM
finally installed a different transmission with new TOB and clutch pulley. Now Eddy’s 914-8 back on the road.
ValcoOscar |
Oct 30 2019, 03:33 PM
Garage Life Group: Members Posts: 2,374 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
finally installed a different transmission with new TOB and clutch pulley. Now Eddy’s 914-8 back on the road. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/red914.jpg) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/clap.gif) (IMG:style_emoticons/default/clap.gif) (IMG:style_emoticons/default/clap.gif) (IMG:style_emoticons/default/clap.gif) |
Lo-Fi Version | Time is now: 23rd April 2024 - 08:58 PM |
