Renegade Instructions, Need some information |
Dunc |
Oct 19 2019, 09:33 PM
Newbie Group: Members Posts: 37 Joined: 4-July 14 From: Kennewick, WA Member No.: 17,590 Region Association: Pacific Northwest |
I purchased a Renegade repowered 914. I am considering installing a crate engine, and I would appreciate it if anybody has the manual or the instructions published by Renegade. Thanks.
jimkelly |
Oct 27 2019, 12:49 PM
dick here is a quote on another thread from dunc. seems he has a non or poorly running 307.
"Based on the valve covers, mine is definitely pre 86. The block is a p.o.s 283. Crank is 327. So the motor is a sucky 307. Heads are refurbished. I have a 901 xmssn, which I plan to upgrade with heavier duty axles. I figure the xmssn will be good for 330hp with the heavier axles. So the plan is to just get a crate motor. My concern all along has been about any mods that must be done to the replacement engine before installing it. I will stay in contact. Thanks again for the help. Dunc " |
DickSteinkamp |
Oct 27 2019, 01:10 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
dick here is a quote on another thread from dunc. seems he has a non or poorly running 307. "Based on the valve covers, mine is definitely pre 86. The block is a p.o.s 283. Crank is 327. So the motor is a sucky 307. Heads are refurbished. I have a 901 xmssn, which I plan to upgrade with heavier duty axles. I figure the xmssn will be good for 330hp with the heavier axles. So the plan is to just get a crate motor. My concern all along has been about any mods that must be done to the replacement engine before installing it. I will stay in contact. Thanks again for the help. Dunc " Yea, I saw that Jim. I couldn't tell if he just didn't like any 307s (and 283s apparently) for some reason or if his was in need of replacement. ALL 307s have the 283 bore and the 327 stroke. I was also unsure of why he needed the Renegade instructions if it was just a 1/1 exchange of one SBC for another. If that's all it is...a 350 to replace a 307....should be pretty simple. |
Dunc |
Oct 27 2019, 09:31 PM
dick here is a quote on another thread from dunc. seems he has a non or poorly running 307. "Based on the valve covers, mine is definitely pre 86. The block is a p.o.s 283. Crank is 327. So the motor is a sucky 307. Heads are refurbished. I have a 901 xmssn, which I plan to upgrade with heavier duty axles. I figure the xmssn will be good for 330hp with the heavier axles. So the plan is to just get a crate motor. My concern all along has been about any mods that must be done to the replacement engine before installing it. I will stay in contact. Thanks again for the help. Dunc " Yea, I saw that Jim. I couldn't tell if he just didn't like any 307s (and 283s apparently) for some reason or if his was in need of replacement. ALL 307s have the 283 bore and the 327 stroke. I was also unsure of why he needed the Renegade instructions if it was just a 1/1 exchange of one SBC for another. If that's all it is...a 350 to replace a 307....should be pretty simple. Actually that sums up the situation. The 307 doesn't have enough grunt. It runs ok, but I think that a 327 or 350 is the better alternative. I haven't heard anybody say that any mods to the engine are necessary, so I assume it is a straight swap out. By the way, I never heard a $ amount for the 283. Did I miss something? With that said, this conversation seems more in line with the Garage Forum, so as any more questions occur, I will start a thread on that forum. |
DickSteinkamp |
Oct 28 2019, 08:42 AM
dick here is a quote on another thread from dunc. seems he has a non or poorly running 307. "Based on the valve covers, mine is definitely pre 86. The block is a p.o.s 283. Crank is 327. So the motor is a sucky 307. Heads are refurbished. I have a 901 xmssn, which I plan to upgrade with heavier duty axles. I figure the xmssn will be good for 330hp with the heavier axles. So the plan is to just get a crate motor. My concern all along has been about any mods that must be done to the replacement engine before installing it. I will stay in contact. Thanks again for the help. Dunc " Yea, I saw that Jim. I couldn't tell if he just didn't like any 307s (and 283s apparently) for some reason or if his was in need of replacement. ALL 307s have the 283 bore and the 327 stroke. I was also unsure of why he needed the Renegade instructions if it was just a 1/1 exchange of one SBC for another. If that's all it is...a 350 to replace a 307....should be pretty simple. Actually that sums up the situation. The 307 doesn't have enough grunt. It runs ok, but I think that a 327 or 350 is the better alternative. I haven't heard anybody say that any mods to the engine are necessary, so I assume it is a straight swap out. By the way, I never heard a $ amount for the 283. Did I miss something? With that said, this conversation seems more in line with the Garage Forum, so as any more questions occur, I will start a thread on that forum. Thanks, Dunc. |
Lo-Fi Version | Time is now: 24th April 2024 - 03:43 AM |
