Pinging under acceleration |
solex |
Oct 20 2019, 06:30 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I recently noticed that the engine in pinging upon acceleration. I checked for vacuum and fuel leaks but could not find anything after a complete tune-up.
I took apart the distributor and notice some broken plastic pieces on the trigger points, any idea as to what these may be? I also noticed that the advance springs are quite different from one another, I have read that this is typical but could not find a definitive answer as to what are the correct springs. The distributor is from the original engine with an air pump and CAT, should the springs be replaced, if so what would be a good source I also checked the vacuum canister and it holds a vacuum and retards/advances the plates. Last question is there a better way to ground the two plates together, they are ok for now but it looks a bit tenuous? Any help here would be appreciated, thanks, Dan Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 29th May 2024 - 04:55 AM |
